My philips MP3 player will not turn on even though it is fully charged not on lock, and in "should be" perfect condition since I just got it a few days ago. I've tried reseting it and that hasn't worked either. Please help.
  • happyjazz Jul 28, 2008
    its fully charged and i,ve connected to the mains and nothing happens
  • David Simpson May 11, 2010
    Model number?
  • 476 Answers
Cleared
Posted on May 28, 2008
My mp3 will not start, even after a charge
Um honestly .... well, if it will stay on though it's blank, it should be reformattable. If it simply will not turn on even though it's fully charged ... unfortunately it's probably destined for the trash bin.
Jul 13, 2014 | Eclipse 180 G2 Sl 180G2 4Gb Mp3 Music &...
I am charging the battery of a brand new purchase. Do I need to let the battery charge fully, ie; the 3.5 hours before I can use it? I keep getting a, "Key LOCKED, system shutting down message on the...
For the initial charging, YES, you need to follow what's on the manual. If it requires you to charge the player for 4 hours as the initial charging, you need to leave it connected to the wall outlet for 4 hours, so that the battery life will become longer.
Though the key is locked, it's still charging. As long as it's connected to the outlet.
Thank you.
Nov 03, 2010 | SanDisk Sansa e200 MP3 Player
My philips go gear 4GB wont turn on even though it is charged
There is a small hole on the side of the player through which you need to use a small office pin to reset. press it for some 5 secs and release. the playerr would have hung up earlier and is now reset. you can now switch it on. Hope this clears. Good day
Jul 02, 2010 | Philips Electronics - Others
It powers on then right back off, has a full charge just won't stay on
Please make sure that the battery is fully charged .. If not please discharge and charge it fully...
May 27, 2009 | Philips SA3025/37 Flash MP3 Player
I have a 8gb GoGear it turns off immediatly when i turn it on
Make sure the lock switch was not accidentally engaged, and try powering on one more time. If that fails, plug the mp3 player into the computer, open the Philips Device Manager and run a Repair - it will give on-screen directions once you have clicked the Repair button. Warning: Running the Repair will result in all of your songs being erased from the mp3 player.
-Tha Mp3 Doctor
Feb 14, 2009 | Philips GOGEAR SA6045 MP3 Player
My Philips Go Gear SA3025/37 MP3 player won't charge/turn on
i had the same problem. my reset button was jammed. the problem: the reset button is so deep in the tiny hole its hard to tell if you even really hit it when you put a pen in there and somethign like a sharpened pencil just doesn't go deep enough. i monkeyed around wiht a peice of straw in the reset hole for about 10 seconds then tried to turn it on and it worked. good luck
Jan 24, 2009 | Philips SA3025/37 Flash MP3 Player
Will not turn on
Make sure that the hold/lock switch isn't engaged, and make sure it has been plugged into the computer for 3-4 hours to fully charge.
If it still won't work, run a Repair in the Philips Device Manager.
-Tha Mp3 Doctor
Jan 20, 2009 | Philips GoGear SA3125/37 MP3 Player
Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
51 people viewed this question
 Grubhead
Grubhead
