Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Freeze protection is activated on aqualink. Air sensor says 3deg but pool temp says 83deg. Want to know how to adjust air sensor so pool doesn't cycle all night
  • 990 Answers
You don't adjust this. You will need to replace the air sensor. You can get the sensor at or through any pool shop and it is simple to replace. You will find it hanging under your box by the equiptment, or somewhere close in the shade. Follow the wire into the box and find the terminal block it screws into. You will need a tiny flat screwdriver for this. Remove the old one and install the new one, close the box and your done.
Posted on Sep 04, 2010
Freeze protect drops to -20 degrees
need new air temp sensor trade on board with water temp see if it reads different if not need new PCB board
Feb 06, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Aqualink freeze protection
go into system set up find freeze protection highlight what pumps and accessories you want to protect and what temp to activate
Jan 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
Pool spa heater when freezing temp
It normally will heat up with pump moving water, once the threshold is achieved - system will come out of its Freeze protection mode and will begin to work as programmed. If there is a heat call, heater will come on.
You can also locate the sensors, both the Water & Air (they need to be very close in temperature for this to work) then place them in water warmer than the actual ambient temp, & above the temp that triggers "Freeze".
Dec 27, 2012 | Jandy Aqualink Rs4 One Touch Control...
Freeze protection interrupts spa operation in cold weather
the filter pump is used for other features during spa use disable the freeze protection but turn back on after using spa
Jan 01, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
What is the freeze protection temp on a jacuzzi pump set at?
Pumps don't usually have freeze controls they will usually be in another control. Most are set at 38-40 degrees. All are different by brand but I think any run below 36. Be sure that your air temp sensor is OK if your having trouble, This will show on your control pad, and your temp sensor should be located below your control box by your equiptment. Hope this helps, good luck.
Dec 06, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Nov 22, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
201 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
