Question about Ovens
My wall oven will not work. The clock is flashing '0:00 auto', I don't have a manual but the grill works???? Also tried pushing the buttons to set the clock and they don't do anything either???? Is this something to do with setting the clock or is there something wrong with this oven??
  • Ovens Expert
  • 414 Answers
The clock will generally only be linked to the main oven. Can you comment on this post with the make and model and I may be able to assist with setting the clock, If the make is a siemens (as this is the section that you have posted the question in), follow the link below and download the manual to assist with the setting of the clock. All the best.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html open link and then click where indicated to open manual search, then input model number (Enr number).
Posted on Sep 05, 2010
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
Westinghouse oven pof668 in auto mode - how do I get it out of auto mode (am renting this property). Oven and grill are not working as power was off until recently
Most models won't work when on Auto. Generally there are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). Press this button and it should go back to manual mode and allow you to use the oven.
What I have said so far is pretty much a guess, based upon experience. I'm also guessing that you don't have a manual to refer to either. However, w
hile I can't find the specific manual for your model, there is a westinghouse oven manual here:
http://manuals.appliancesonline.com.au/westinghouse-dualfuel-ovens/westinghouse_duelfuel_ovens_manual.pdf
and I would bet that the clock setting instructions on page 18 are exactly the same for your appliance!
Jul 28, 2011 | Ovens
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 | Ovens
Display is flashing0.00 and auto. oven won't work, took out circut breaker still doesn't work. when trying to reset the clock high pitch sound comes on and have to turn oven off at wall to stop
It will not work if it is flashing, the timer needs to be reset to manual
If it will not reset, then It sounds like the timer is faulty, try a different combination of buttons when trying to reset it.
Hope this helps.
Feb 02, 2010 | Ovens
My oven wont work afte a power cut its flashing oo:00 auto and I dont have a manual
you have 2 buttons one pops out for adjustment the other is only a push button push the left hand one repeatedly till a red clock symbol shows at top of clock then turn right hand knob to set time wait a few seconds and clock will set itself.
Nov 16, 2009 | Neff B1421 Electric Single Oven
Cant fix the clock to work without the timer
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
hope this helps
Jul 09, 2009 | Neff B1421 Electric Single Oven
Kleenmaid Scala wall oven and grill
manual available at www.kleenmaid.com/care
Jan 17, 2009 | Ovens
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
May 07, 2008 | Ovens
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
1,136 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
