Hi there, I am having major problems here, I upgraded to windows 7 and it was working fine, then it had a black screen with something about 7600 and windows is not genuine, just this last time that I tried to log on, I got a blue screen with white letters, I need your help please
  • 570 Answers
The windows 7 which you were using was a trial version for 30 days or more.It is showing that windows is not genuine because your trial period is over.
Now you have to again format your PC, if you want to use windows 7 trial version then every time you have to format after your windows had expired.
Or just simply format with other operating system.
Thanks.
Have a great day
Posted on Sep 04, 2010
Remove wat could not solve my window is not genuine build 7600 problem give me another aolution
Windows 7 Build 7600 by default will not allow you to do an upgrade install.
This how to will describe the process needed to upgrade from Windows 7 Build 7100 to Windows 7 Build 7600 with out doing a clean install.
Download the ISO as you did previously and burn the ISO to a DVD.
Copy the whole image to a storage location you wish to run the upgrade from (a bootable flash drive or a directory on any partition on the machine running the pre-release build).
Open the file cversion.ini in a text editor like Notepad
Modify the MinClient build number to a value of 7100.0
Save the file in place with the same name
Run setup like you would normally from this modified copy of the image and the version check will be bypassed.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB.
You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://100-downloads.com/publisher.php?pb=http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool&dl=727
http://download.cnet.com/windows-7-usb-dvd/3000-18513_4-10972600.html
Create a copy of your Windows 7 ISO file on removable media
Sep 27, 2013 | Compaq Presario CQ62-209WM Athlon II X2...
Everything is fine except for crashing (blue screen) or just blacking out. Can restart automatically or I have to remove the battery, power supply retry several times.
Hello the homepage is here:
http://www.dell.com/support/drivers/us/en/ussoho1/Product/inspiron-1520
Windows 7 is not a supported system.
Especialy not the 64 bit. The 32 bit will probably work fine.
Try to install the newest graphic driver and upgade the bios to the latest version.
DO NOT run the bios upgrade before the system is running fine.
Install any missing drivers.
Look in the device manager.
Any file here from dell needs to be unziped before you install it.
Good luck
Nov 25, 2012 | Dell Inspiron 1520 Motherboard
Time of this report: 5/23/2011, 15:20:31 Machine name: MIRO-PC Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255) Language: English (Regional...
The embedded video chip in this pc or the optional add-on video cards that were offered with it are extremely old models, that are just Dx8 compatible. Win 7 need a video card that is at least Dx9.2 compatible = you will need to upgrade your video with something like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7189043&CatId=318
May 24, 2011 | HP Compaq d530 CMT PC Desktop
I'm having this error on my laptop.my screen shows windows 7 build 7600 this copy of windows is not genuine
You will need to activate your copy of Windows 7. Once this is done this message will dissapear. If the activation fails then this means that you may be a victim of software piracy, contact the microsoft support center an Microsoft.com
Feb 12, 2011 | Microsoft Windows 7 Professional Upgrade...
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
I have a dc 7600 desktop when i install win 7 32 bit in to my computer my computer can not reboot and shows black screen can dc 7600 run win 7 or not please ans me
If your PC meets the minimum specifications ie 1Ghz CPU and 1Gb of Ram then it should be able to run Windows 7. You can try repairing the installation by following the instructions below :
  1. Place the Windows 7 installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. The computer should automatically give you an option for startup repair, if not proceed with step 7
  7. In the System Recovery Options dialog box, click Command Prompt.
  8. Type Bootrec.exe, and then press ENTER.
When the repair is done remove the Windows 7 disc and reboot the PC.
Hope that works for you.
Sep 08, 2010 | HP Compaq dc7600 PC Desktop
Will this product work with Win 7?
The system requirements for this unit are xp, vista.
Just so you know. Now if you have version 7600 of windows 7,
I would say yes it should work, but I put the requirements so you know.
I have not had anything not work with 7600, I have run XP requirements
in windows 7. 7600.
It would be best if you purchased this from a place you could return it.
Not because of windows, but who knows what kinds of errors you have created in the registry and it might not work because of other reasons.
I'm not trying to knock you, but I come across tons of problems that are because people can't run windows and create all kinds of problems but blame windows.
Windows is garbage, but usually made worse by its owners.
Feb 08, 2010 | Zalman Tech ZM-RSSC External Sound System
After upgrade from Win Vista, the screen dont work on Win 7
One word DRIVERS. This is ya whole problem... simply Win 7 doesn't have the correct drivers for your PC. Unless ya have the correct drivers ya gonna always have problems. Find suitable drivers for everyone of your devices and store in a Directory, when you install, then, ya will have the correct drivers and hopefully Win 7 will install fine. Remember also Drivers can be installed in "Computability Mode" for XP SP2. Otherwise stick with Vista?
Jan 26, 2010 | Computers & Internet
Hi i have a KT4V motherboard and recently got a radeon 9800 pro graphics card - and upgrade form a radeon 9250 (which worked fine on xp but when i upgraded to windows 7 it wasn't supported). when i first...
Yes and No. Let me explain. You have taken an older board that worked with XP and tried to make it work in Win7 (which is not supported by the board). Add in your graphics card switch, and you have a real mess.
You can upgrade your motherboard (for one that is compatible with Win7 - (ie. a brand new model with Win7 certification) and use a graphics card that is also Win7 compatible, or
Go back to a configuration that worked
Dec 16, 2009 | MSI KT4V (MS-6712) Motherboard
Has anyone been able to upgrade Acer Aspire 5735Z to windows 7 ?
i have done this with this model if its just the upgrade pack your not changeing anything so all drivers will be the same and will work well
Nov 24, 2009 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
