Need remote code for KDL-52W4100 (Sony Bravia LCD Digital Color TV) AND for the Sony DVD Home Theatre System DAV-HDZ273
SOURCE: How do I reset a Somy bravia KDL-52W4100 back to
While holding down the UP arrow key, press the power button. The TV will turn off and back on and reset to factory default settings. Hope this helps
Posted on Oct 05, 2009
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Posted on Nov 24, 2009
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 117 Answers
SOURCE: sony bravia needs a new remote, have bought a
go on line to sony they will send new one at cost
Posted on Jun 30, 2010
  • 5 Answers
SOURCE: Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Posted on Dec 06, 2010
Remote not working
i want to buy a remote control for sony dvd home theatre system dav-fxg9k, where i can get it?
Jan 11, 2014 | Sony SS-FXG9K Multi-System Region Free DVD...
Sound Problem
I'm unclear about the comment"If I play a DVD or net fix through separate box" What do you mean by separate box? Please reply.Be specific about what inputs on the tv and what settings you have check in menu as far a sound id concerned.
May 31, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi i have a silly question??? i have a sony bravia kdl-32bx300 television and a sony dav home theatre system so i have connected it and all and it works just fine except .... i would like to know what do i...
If you get your TV programming froma Cabel or Sat Box, run the audio directly from it to the DAV. There is never a compelling reason to pass audio through a TV on its way to audio gear.
Feb 05, 2011 | Audio Players & Recorders
Does this model have Bravia sync?
Yes it does per SONY web site:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665164630&langId=-1#specifications
BRAVIA® Theatre Sync™ technology
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
Feb 02, 2011 | Sony BRAVIA KDL-40V3000 Television
I cant find remote for 52" Bravia tv. Can I turn
Yes, you can turn it On-Off by pressing power button on side of tv.
Required tv remote for KDL-52W4100 is available at Remotes.com
Hope these info will help you.
Thanks.
Nov 05, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We need our Sony 52W4100 Bravia screen replaced. What is the cost?
Sony BRAVIA KDL-52W4100 52 in. HDTV LCD TV
Part # 1-802-791-12, cost approx $2,251.54 + core
Parts reference: Andrews electronics, 800 289 0300.
May 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Lots of components , need proper hook-up
I reccomend a Denon AVR-2809. It had 4 HDMI inputs, all 1.3a and higher, and one HDMI out for your TV!
Jan 07, 2009 | Audio Players & Recorders
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
