Question about Haier CPRB09XC7 Portable Air Conditioner
We purchased a haier air conditioner cprb09xc7. A mildew odor is coming from the a/c unit. we tried emptying the water from both outlets, but the odor still presists. We cleaned the filter also. Still the odor comes back. What next?
rpbuice
  • 161 Answers
SOURCE: taking 2 hours to dry load of clothes
I always first check the air flow. Turn the dryer on and check the air flow outside at the vent. If your not sure what a good air flow would be then disconnect the vent hose at the dryer and feel the air flow at the dryer and compair to the outside.
If the air flow on the outside is not what it should be then a leaf blower hooked to the inside vent hose will clear it out.
Good air flow, then I put an oven thermometer at the dryer air discharge to check the temp.
It should cycle between 100 - 150 degrees, if not, then let me know what it's reading
Posted on Dec 21, 2008
SOURCE: my window a/c is experiencing a terrible odor mildew smell when I turn it on if I lower the terminstat to 70 it smells worse then if the termastat is 65 I cannot stand this odor I cleaned the filter m
TAKE OUT YTHE A/C CLEAN THEN REINSTALL IT ALSO CLOSE THE FRESH AIR PORT
Posted on May 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: MILDEW ODOR IN MY HE3 MACHINE
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
pendletonhea
  • 144 Answers
SOURCE: The inside of my air
Ruth this happens alot ive answered alot of questions so im going to make it short please give me a vote and rating the unit needs to be pulled out and taken out side sprayed really well with cleaner homedepot and lowes sells coil cleaner in their a/c dept. it isnt as good as what your local a/c man can get but will do what happens is the consensation stays in those systems cause the deposits and rust in the drain sometimes clogg the exit when your not useing it it has water that will set their for months at a time the mildew is the least of your worry in most cases theirs mold present as well and as brings spiders and misqitoes I dont know if you can install one in that unit or not but seach online uv lights for a/c systems I think you will like what you see
Posted on Sep 22, 2010
  • 4736 Answers
SOURCE: The air coming out of
Actually, sportsfan, you don't need to add any water. In fact, there is no way to do it. Your unit works much the same way a dehumidifier does with auto evaporation function. In other words, it collects the humidity out of the room air a evaporates it, so there is no water removal on your part involved. While this water is being evaporated, it's also being cooled, so that cools your room. The hot air of the unit running is exhausted out through the window vent kit.
To replace your Owners Manual call Haier Customer Support 877-337-3639
Hope this helped answer your question. Please let me know. Thanks.
Posted on May 04, 2011
While on, air smells like mildew.
Is this a window unit?
I’m happy to help further over the phone at https://www.6ya.com/expert/david_66a56a0239b6ab32
Jul 28, 2015 | Haier CPN14XC9 Air Conditioner
Why do I have to empty water every 1/2 hr?
Because it is removing the much moisture out of the air. You can run plumbing out the back of it to the outdoors or floor drain.
Jun 27, 2015 | Haier CPRB09XC7 Portable Air Conditioner
Where do I go to find a part for this unit?
Haier Air Conditioner Parts ' Haier A/C Parts from PartSelect
May 27, 2014 | Haier CPRB09XC7 Portable Air Conditioner
Dont know how to get the ac turned on
Downloadable manual:
Haier CPRB09XC7 - 9K BTU Air COND Manuals
Aug 27, 2013 | Haier CPRB09XC7 Portable Air Conditioner
Need blower wheel for commercial cool model cprb09xc7
To find the blower wheel you need for your Haier AC, go to the following link.
http://www.partlinx.com/haier.asp
Thanks for using FixYa.
Jul 29, 2011 | Haier CPRB09XC7 Portable Air Conditioner
No cool air coming out of unit...tried cleaning filter
REMOVE THE PLUG AND DRAIN THE UNIT IF THERE IS TOO MUCH CONDESATE (WATER) THIS UNIT DOES NOT COOL.
BEST OF LUCK.
Jun 02, 2011 | Haier CPRB09XC7 Portable Air Conditioner
The air coming out of my Haier CPRB09XC7 Portable Air Conditioner has gotten warmer and dryer. I'm sure that i need to add water but i do not know how as the manual was lost a while ago. Do I just need to...
May 04, 2011 | Haier CPRB09XC7 Portable Air Conditioner
The inside of my air conditioner is full of mildew. When turned on, it spits out small pieces of black mildew. The odor is very obvious. I cleaned the louvers (as much as I could reach) with a Q Tip and...
Sep 21, 2010 | Haier Heating & Cooling
I have an Everstar portable A/C unit that I purchased from Home Depoy 2 months ago. It works fine but it has begun to stink. How do I stop the odor?
There is water(condensation) that has built up in the unit and is stinking due to the water is growing mildew. Is the air conditioner condensation line plugged? If this is a window unit also make sure that it is level or not all the water will drain out and cause this odor. The odor should diminish after the water has completely dried out.
Oct 11, 2009 | Heating & Cooling
Haier CPRB09XC7 Portable Air Conditioner Logo
147 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
