Question about Olympus FE-170 Digital Camera
Battery empty - Olympus FE-170 Digital Camera
    New Friend:
  • 121 Answers
Charge your battery using its data cable.If it is not charged check your charger.Now if your charger also good.Then buy a new company branded battery and replace it
Posted on Sep 04, 2010
SOURCE:
Nikon D80 showing empty battery
Are you using the same charger for all of the batteries? If so, you might want to try another charger. I had a charger for my batteries (I have a D7000) that turned out to be bad. It would show it charging and then having charged them, but they were still dead.
If that's not the case, check the contacts inside the camera, that they are clean and free of debris. Those little gold contacts needs to match up nice and solidly.
If it's still a no-go, call 1-800-NIKON US (1-800-645-6687) 9AM-8PM EST, Monday through Friday.
Mar 16, 2014 | Nikon D Cameras
Nokia 3110 calling time battery empty and switch off
when i power on the mobile show battery empty after show nokia icon then mobile power off
Oct 14, 2010 | Nokia 3110 Cellular Phone
New battery is considered Empty
Some cameras, even the expensive Nikon professional cameras have the same problem. Sometimes turning it on and off fixes it, sometimes removing and reinserting the battery works. Sometimes, going into the menu and finding "reset" works.
Feb 11, 2010 | Olympus SP-310 Digital Camera
Battery shows empty with new batteries. Recent development. Put batteries in, take a couple shots, battery is empty. Tried with several pairs of batteries. Contacts OK and tight. Suspect a software...
Take a look in your camera's menus. There should be a place where you can select rechargeable or non-rechargeable batteries. That setting enables or disables the battery charging circuit. If you are using rechargeable batteries, the camera must be set accordingly so that the battery charger will turn on. If you are using
Alkaline batteries such as Duracell or other types of non-rechargeable batteries the charger must be disabled. If you do not set that parameter correctly, you will get the symptoms you describe.
Oct 04, 2009 | Pentax Optio M20 Digital Camera
Compatible Battery problem
Try clean contacts of the battery. If problem persists, note what is on the LCD when it turns off. Only symbol of an empty battery, or is there any text? If there is written "For InfoLithium/compatible battery only", it does not mean that the camera thinks the battery is empty, but that the battery do not communicate with the camera. If other batteries are OK, you should replace the bad one.
Sep 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Hi, I have a Nikon D300. First problem - The battery started showing empty / full / then empty again. Bought a new battery, worked first time, then the same problem empty / full / empty. Change the...
A capaciter in your camera is not working properly and is discharging your battery even when the camera is turned off (this is a cheap problem to fix but must be sent back to NIkon for repair
Dec 06, 2008 | Cameras
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
Battery empty error on screen
Try NiMH rechargeable batteries or AA Lithium batteries.
Jul 26, 2008 | Olympus FE-210 Digital Camera
DCR-PC1E
there can be many reasons. rusted contacts, or blown up fuses, or a short circuit in the power board, and may be some thing else. No one can help unless he examines the camera.
Sep 11, 2006 | Sony DCR-PC55E Mini DV Digital Camcorder
Olympus FE-170 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
