Question about eMachines T5274 Desktop PC
Emachine loop again
HI, i have the same problem as someone else that you posted a reply to below. Your solution is their recover disc for their Emachine, but I don't have it. Any other suggestions?
I continue to get this error message (as if it is in a loop, and can’t get out.)
Windows didn’t start successfully. A recent hardware or software change might have caused this. [nope]
"If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files or folders, choose “Last Known Good Configuration” to revert to your most recent settings that worked.
"If a previous startup attempt was interrupted due to a power failure, or a Power, or a Reset button being pressed, or if you aren’t sure what caused the problem, choose “Start Windows Normally.”
[choices]
Safe Mode
Safe Mode with Networking
Safe mode with Command Prompt
Okay. Regardless which option I choose above, it loops, and returns to this page.
  • Anonymous Jan 12, 2009
    While I was trying to perform system restore, the power was knocked out and my computer shut down and will not let me back in. I have tried using F10 , F3, F8 and so on... and I still can not even get it to start in Safe Mode. My computer keeps going in and out. How can I get my computer to start up normally again , as well as being able to get back on the internet? Thank You.
  • Janice Miller May 11, 2010
    I tried all these things and it still does not work. I can not get my computer to start up at all. It won't even let me go into safe mode. I NEED HELP!
    Genius:
  • 2,985 Answers
Try first of all 'Last good configuration'
If still no go consider what it is you have done latly in termso of installing new software or a new hardware device.
Remove the most recent.
Finally in Safe Mode go to Start/Programs/Accessories/System Tools/System Restore and reset the machine to a time before the problem started.
Posted on May 12, 2008
2 Suggested Answers
  • 16 Answers
SOURCE: eMachine ailment
start it with a bootdisk then run scandisk from the prompt (scandisk c:) then run fdisk /mbr (fdisk /mbr) hopefully this will work is not then recover the system
Posted on May 14, 2008
How do i make a banded treble stitch please
  1. Yarn over hook three times, then insert hook into next stitch.
  2. Yarn over hook and draw yarn through stitch (there are five loops on the hook).
  3. Loop yarn over hook and draw through two loops (there are now four loops remaining on the hook).
  4. Yarn over hook and draw through two loops (there are now three loops remaining on the hook).
  5. Yarn over hook and draw through two loops (there are now two loops remaining on the hook).
  6. Again, loop yarn over hook and draw through the last two loops on the hook (there is now one loop remaining.)
  7. This completes one double treble crochet.
Jan 30, 2015 | PTAJ Marketing Crocheting Stitches
I lost my disc and ca't install the webcam
You can download the drivers from the link below
Micro Innovations IC4320CHS Web Cam Driver
feel free to reply to this post if you require more assistance
Regards, BA
Jan 15, 2011 | Micro Innovations IC4320CHS Web Cam
Could you please tell me how to make a backup restore disc for my emachine
u can use ntbackup utility so u can take backup of ur computer and then u can restore it.
also u can use different third party applicaiton which can take image of ur whole system and then u can recover it even if u dont have installed OS on ur machine.
if you have puchased computer with disc recover then
u can go to program files and u can find the application there and make recovery disc
every vendor has different method of recovery discs.
Jun 17, 2010 | Computers & Internet
Will not recover past asking for disc. no. 2?
Emachine, usually comes with two or 3 disk sets. First one install drivers and partition files then second or 3rd one install xp or vista
You may order from Emachine support page.
Aug 15, 2009 | E-Machines T2778 PC Desktop
I"m trying to hook up this Emachine and im having proble4ms connecting cdrom floppy hardrive
An external drive would have a cable you connect to the back of your tower. An internal would not have this but would connect directly to your motherboard on the inside of your PC Tower.
Based on your follow up question it appears you want to connect to an inside pin out connection point. Is this right? And if so, what type of cable do you have that need to connect? Is it thin and round or flat and wide?
Thank you for your patience. One of use will be able to help you further once you post this information. Sorry, but we actually need to konw this in order to solve your problem.
Regards,
Worldvet
Please use th comment box below to reply.
Aug 18, 2008 | Computers & Internet
Emachine failure. no recovery disc.
just go to www.newegg.com and purchase an OEM copy of Windows XP for 99 bucks. thats your best bet. Or you may have a recovery partition on that desktop...if you press f11 when you turn it on it may let you recover from that. good luck
Jul 29, 2008 | E-Machines eMachines Desktop PC
Engine missing
Hi again,
Appreciate the "Ask Me". With your indulgence, I would also be posting this reply in your original post here.
The fuel pump is inside the fuel tank as shown in diagram below.
Vacuum leak could of course cause poor performance on take off on engine speed below 3000RPM. Another indicator of a vacuum leak is slight above normal idling with the exhaust fumes hurting to the eyes.
Jul 26, 2008 | 1991 Daihatsu Charade
My emachine computer is to slow.
I just did a complete recovery to an eMACHINE COMPUTER without the disc that comes with the comp. first step is to save any document , files , photo , music & video to a CD-R , external hard drive , or another comp. when ready turn on comp. yor gonna see the initial black screen with the big " e " following the technical data information , look down where it says RECOVERY and follow instructions , hope this helps
Apr 28, 2008 | Computers & Internet
Need large disc support for old emachine, flash bios? or try restore cds?
flashing a bios, can render your machine/motherboard useless.
You should always ensure any bios download is from a trusted source. if you experience a power failure, or an incomplete bios file. your computers as good as dead.
Windows 95/98 only supports disk drives to a certain capacity. if you updated to windows 2000/ME/XP your problems may be solved. I,d certainly try that first.
Bios flashing Last resort, even after finding a reliable bios update. also ensure the bios file is 256mb-512mb or equivalent. as this is standard bios file size.
Finally check that your hard-drive does not have a jumper ( Small white/black ) plastic block restricting the drives registered size.
When you install windows XP, it will ask you if you wish to enable LBA ( large block Allocation ) Select Y ( yes )
Mike @ compurepair.
Mar 12, 2008 | E-Machines eMachines Desktop PC
eMachines T5274 Desktop PC Logo
210 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
