Question about Nokia 5800 XpressMusic Smartphone
It takes 5-8 seconds when opening a folder - Nokia 5800 XpressMusic Smartphone
  • 70 Answers
This is because your internal phone memory is getting full. Try deleting some media (not on your memory card) from your phone. Clear browser history and cache. If it is still running slow try doing a full factory restore (usually involves erasing all your data and contacts so make sure you back them up.)
Please rate me, thanks.
Posted on Sep 04, 2010
  • 952 Answers
Remove some applications, you may be using too much memory
I can open the flash drive in my computer, but none of the files are showing, and I can't make new folders. It will say, Unable to create folder 'New Folder' The system cannot find the file...
Hello Michael j803
please read all before attempting this....
1. remove flash drive
2. restart computer
3. insert flash drive
4. if it does not auto open go to my computer / right click and a menu should appear click open in new window
5. files should be displayed
6. if not you may want to reformat flash drive ( if nothing vital was on it ) right click on flash drive and choose format from menu
7. in the format menu uncheck quick format and click ok.( this may take a while follow on screen prompts )
8. put something on drive and check it is there.
9. if you have something important on drive google a free recovery program install and try that.
10. if nothing happens the drive may be faulty.
11. if you have second computer test it there first to see if ok.
Feb 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
"uncaught exception: application net_rim_bb_messaging_app(303) is
Take the battery out for 5 seconds or so... This will fix many smartphone os problems.
Dec 13, 2010 | Cell Phones
My problem is that I have a laptop hard drive, that's having issues. I can open my files, and I can't open a USB folder to back up the files. What should I do?
Enable "File and Print Sharing" on your Windows system.
Then, "share" your 'My Documents' folder.
Use an Ethernet cable to connect your computer to any router.
Take another computer, and another Ethernet cable, to connect this second computer to the same router.
Make sure that both computers are in the same Windows "workgroup".
On the second computer, "browse" the local network.
You should see your laptop computer, and the "shared" folder that it is offering.
Copy everything, over the network, from that folder onto the second computer.
Backup the files to a DVD-recordable disk, or to an external storage-device.
Nov 20, 2010 | Gateway Computers & Internet
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
Screen is frozen, can be turned on and off but wont go passed initial stage
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
May 17, 2010 | CaseCrown Navman S50 Portable GPS...
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Opening folder slowly
You might need to regularly delete files like text's etc. to keep the phone running a little faster.
Apr 02, 2009 | Nokia 6270 Cellular Phone
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Won't take pictures
hi
the solution for your prob is...
1-connect ur mobile with your PC.
2-open the file manager
3-then open pictures
4-now the folder which camera photos save
delete that folder
5-n make new folder n give that same name to this folder (which named folder u hv deleted)
6-now u can use ur camera properly.
good day
Jan 30, 2008 | Sony Ericsson W800i Cellular Phone
Problem In Control Panel
near microprocessor change c945b transistor, this may help u
Sep 08, 2006 | SAMTRON 55V 15" CRT Monitor
Nokia 5800 XpressMusic Smartphone Logo
107 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
