When installing 2 speakers to a 4 channel auto receiver do I use the left and right front speaker wires and ignore both rear speaker wires or do I gang both left wires and both right wires?
  • 32,281 Answers
I suggest you ignore the rear speaker connections.
OR
Get another 2 speakers and wire up the rear speakers.
Posted on Sep 04, 2010
Testimonial: "Thanks. Ignored the rear speaker wires and had a smooth install that sounds mighty fine."
95 s10 blazer 6 speaker stereo what are speaker wire colors harness was cut 6 speaker not 4 ..dash .front door . Back door
This year never came with 6 speakers (4), so what wiring is installed for those 2 add on speakers I would have no idea.
Here is the factory wire colors from the manual.
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 07, 2016 | Cars & Trucks
95 Jeep Wrangler wiring harnesses broke down by color to show where each wire goes to
Car Radio Constant 12V+ Wire: Red/White Car Radio Switched 12V+ Wire: Purple/White Car Radio Ground Wire: Black Car Radio Illumination Wire: Blue/Red Car Radio Dimmer Wire: Red/Black Car Radio Antenna Trigger Wire: N/A Car Radio Amp Trigger Wire: N/A Front Speakers Size: 4? x 6? Speakers Front Speakers Location: Dash Left Front Speaker Wire (+): Gray Left Front Speaker Wire (-): Yellow Right Front Speaker Wire (+): White/Red Right Front Speaker Wire (-): Brown/Red Rear Speakers Size: 4? Speakers Rear Speakers Location: Rear Roof Left Rear Speaker Wire (+): Gray/White Left Rear Speaker Wire (-): Brown/White Right Rear Speaker Wire (+): White/Black Right Rear Speaker Wire (-): Brown
Oct 04, 2016 | Crown Jeep Wrangler yj 95 94 93 92 91 90...
I have 4 speaker wires, black green red white speaker left + speaker right + speaker left - speaker right - which cable goes where?
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifier´s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Sep 17, 2010 | AudioSource Amp Four 2-Channel Amplifier
Wiring speakers
your main 2 speakers (front left & right)..hopefully the 5th speaker is a subwoofer right if not it will be...the last 2 speakers will be use as the rear (left & right)...in order for this to sound correct the receiver should have a button (5:1) depressed ...otherwise you just have 5 regular speakers...
Jun 24, 2010 | Denon AVR-1400 Receiver
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
The clarion cz209 receiver has two constant 12v yellow wires, which one do i connect the constant 12v on the wiring harness for my 1995 jeep wrangler?
do u have a red as well or just two yellows if so it trial and error connect one to the constant and one to switched then program your radio channels then turn the ignition off then turn it back on if the radio stations stay then you have the right wire if they dont then switch the two yellow ones around
hope this helps pls rate
oh here's a wiring diagram for your car too
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Front Speakers Size: 4′ x 6′
Rear Speakers Size: 4′
Sep 08, 2009 | Clarion CZ209 Car CD/ MP3 Player
I am trying to install my xtant 604x after i just had it sent out and repaired. I have 4 rca's coming from the head unit wired to the amp as FL, FR,RR,RL. The front speakers connected to the front output...
CLICK HERE for your Owners manual in PDF format
CLICK HERE for your Installation Guide in PDF format
As we agreed in chat - you are going to run your 4 channel amplifier as follows...
Front Channels of amplifier will run left and right independently.
Wire up the left speakers in parallel all + together and all - together.
This will yield a 2 Ohm load.
To the Same with the Right Side speakers - on the FRONT Right channel of the amplifier.
Now you have a 2ohm stereo load on the FRONT channels of your amplifier.
And using the BRIDGED nomenclature on the REAR channels of your amplifier - wire up your 4ohm sub mono.
Here is a crude drawing for a visual
Thanks for using FixYa - a 4 THUMB rating is appreciated.
Sep 05, 2009 | Car Audio & Video
Installation
If you've got a standard 4 speaker system (2 front, 2 rear), your best option is to connect both left speakers to the left channel amp output and both right speakers to the right channel amp output. The only thing you lose is the ability to fade the speakers front to back.
Mar 04, 2008 | Legacy - American II: 2 Channel 1200W...
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
55 people viewed this question
 Grubhead
Grubhead
