Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore Elite D/W model #665.16293401; purchased Aug. 2005 D/W will not operate. Per instructions on FixYa, alternately pressed "normal wash" and "heated dry" buttons to reset the D/W. Doing this did cause every light - including the start/resume light - to illuminate; then D/W went through and completed a test wash mode, but would not perform (start light failed to illuminate) a regular cyle after that. All other buttons - except start/resume - illuminate. D/W is not operational without a functioning start/resume light
SOURCE: i have a kenmore dishwasher mode 665.16032402
I have the same problem. I have to go through the test mode at least three times just to wash one load of dishes. This dishwasher is a lemon. Sears she recall it. The techs say that they have at least 50 calls a week with the same problem. We need to hire a lemon law attorney and sue the pants off them. If you here anything email me please.
NewJackSwg@aol.com
Posted on Jan 22, 2008
SOURCE: Red blinking light over normal wash
I had the same problem... the lock on light was blinking continuously. The solution required disassembling the door to get to the control panel electronic board. You'll notice a flat transparent cable coming out of one end, twisting under the board and going into the door panel. In the middle of the door, there's a number of wires taped together that curled over the flat cable. Look for any black tape residue on the flat cable, which seemed to be causing a short circuit and confusing the electronics. After carefully removing the tape residue from the flat cable, the problem went away.
Hope this helps :)
Posted on Apr 03, 2008
SOURCE: K-more elite dishwasher stuck in sensing mode; won't move to wash
Where did you find the sequence to clear the flashing clean light?
Posted on Apr 14, 2009
  • 523 Answers
SOURCE: Dishwasher will not operate. Kenmore 665
control panel
Posted on Jun 01, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Kenmore Elite ULTRA WASH Dishwasher
Hi
This issue appears due to stuck keys on control keypad or due to moisture/shorted connections on the keypad. Sometimes this appears when the door is not closed or door lock switch is failing. Turn off the power to dishwasher, unplug the power cable from outlet or shut off the breaker. Use a multimeter and make sure that the connection to door switch assembly are fine, also check the continuity of the door swiches (when closed). If continuity is present you would need to check the connections to the keypad. Try disconnecting the P1 connector(connects keypad to control board) and then reconnecting it, check if the problem is still present. Replace the keypad if the problem still appears. Please check the below pictures, they might help you--
Link 1 (Door Switch)
Link 2 (Keypad)
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 10, 2011
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
Kenmore Elite washer - control light is on and ii cannot do anything? Please help how do i unlock this feature??
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 29, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash and the machine says contols locked, is there any way to reset that?
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
Elite 45986 Front Load Washer: HI My lchild lock was activated on my kenmore elit...
May 17, 2010 | Kenmore Elite 45986 Front Load Washer
Gorenje washing machine wa 72145 washing clothes but doesnt spin keeps comimg up child lock
May 13, 2010 | LG WM2301H Washer
Why the control locked is on , i have a kenmore elite HE 4t washer can't do nothing to make it go away so won't let me make a wash
Mar 10, 2010 | Kenmore Elite 45986 Front Load Washer
MHW2000 neptune washing machine: There is a burning smell when washing laundry
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####@@@@@
Feb 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine smells like something burning while load was washing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((
Dec 19, 2009 | Maytag Legacy Series Top Load Washer
What ruin washing machine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$##
Oct 18, 2009 | Maytag Legacy Series Top Load Washer
Squeeks when washing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Sep 21, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
127 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
