Question about Skil 2887 - 06 Factory - Reconditioned 18V 2 - Speed Cordless 3/8" Drill/Driver with Stud Finder
Skil 2887-B4 cordless Drill - Chuck spins and secures bit but then entire chuck stops spinning when drilling hole. Is this a gearbox problem. If so, is it better to throw away and buy new drill.
5 Suggested Answers
ccrozier_agr
  • 36 Answers
SOURCE: The chuck no longer spins on my drill
Hi your best chance is to try ebay for one with the motor gone.
Other than that best you can do is buy another drill the same so you will have a spare battery.
You could try Skill for a gear but it probably will be the price of a new drill.
Posted on Dec 02, 2008
  • 3 Answers
SOURCE: How do I change the chuck on a 5 amp skil drill. It is keyless.
If it's anything like their other drills, there is a safety screw with left-hand threads inside chuck.
  1. Turn it clockwise until loose.
  2. Then insert the short arm of a 3/8" hex wrench and tighten.
  3. Strike long arm of wrench sharply counter-clockwise and chuck should loosen to unthread from spindle.
Posted on Jun 24, 2009
SOURCE: Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Posted on Mar 09, 2010
SOURCE: Can't remove the chuck from
Hi
1) check if the chock have a screw fasting it to the arbol if there is one you need to take it out and these crews are left hadle thred
try to fit a pic steel or tool in the chock and tap it hard clock wise then you can take off the screw after tacking off the screw put back the pic steel and tap it hard contra clock wise while holdng the drill and hoppfully it will be out.
Posted on Oct 07, 2010
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
Mar 13, 2015 | Ryobi 18v Cordless Drill - P206 18 Volt V
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
Ryobi 12 volt drill/driver- cannot unlock the keyless chuck
replace the part you have taken out .
get a pair of stilson spanner adjust it so it goes around the chuck and do it and then it will ease off to do it up by hand
Sep 21, 2017 | Skil 2887 - 06 Factory - Reconditioned 18V...
Have a skil 597 T8 thats lost its grip - is it neccy to change the chuck - and if so can I replace the chuck with one that can open far enough to accept some larger bits?
I couldn't find your particular drill model drill. If this is a corded drill with a 1/4 inch chuck, you would do better to just buy a corded 3/8 drill. But otherwise, yes, change the chuck if you can find one to fit at a reasonable price. Drill chucks are sized to hold a straight bit of the maximum hole diameter that the drill has enough torque to drill into mild steel. If you find a larger one that will fit on your drill, it will work fine, but if you overload it you will burn it out. If you don't drill into steel with any larger bit than the original chuck, then this won't be a problem.
Jun 29, 2010 | Skil 3/8IN DRILL CHUCK/KEY
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
We were using a makita cordless power drill. Somehow the clutch got stuck and it won't spin or open where you put the drill bit in. The motor seems to be spinning, think the problem is just in the...
keyless chuck. grab the ring immediately behind the chuck and the tampered chuck piece with a padded channel lock plier. turn the chuck part clockwise to release.
Oct 26, 2009 | Makita Drills
Having problems securing masonary Bit on 3/8 Black&Decker Drill 7
If it's an inexpensive bit, odds are it's spinning in the chuck. If the chuck key can't tighten the jaws well enough, you'll need to borrow or buy a different drill (or you could replace the chuck).
If you bought an SDS bit (one with slots milled in the shank), you're best off buying a bit made for a standard drill. It's not impossible to get a SDS bit to chuck into a standard drill, but it's difficult and they often slip loose during drilling, messing up the hole.
Take care!
May 24, 2009 | Black & Decker Drills
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Jan 28, 2009 | Drills
Oct 27, 2008 | Skil 2887 - 06 Factory - Reconditioned 18V...
Skil 2887 - 06 Factory - Reconditioned 18V 2 - Speed Cordless 3/8" Drill/Driver with Stud Finder Logo
165 people viewed this question
Top Skil Drills Experts
epangan29
Are you a Skil Drill Expert? Answer questions, earn points and help others
