Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What to do when there is an error saying Ld? - Whirlpool Cabrio WTW6600SBT Top Load Washer
    President:
  • 1,932 Answers
Hi, This error code(Ld) indicates that drain times are longer than expected.
1.Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose
2.The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 39" (99 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer.
If Pause/Cancel does not work:
1. Unplug the washer or disconnect the power for one minute.
2. Plug in the washer or reconnect the power.
3. Re-select the cycle and press Start.
Thank You
Posted on Sep 04, 2010
Again and again got a error of sc329 .......how to fix
this error code came from the LD unit which means the seconder LD is not synchronized on the machine but try to clean the mirror if it came agin the replace the LD board
Aug 14, 2015 | Gestetner DSm745 Black and White Copier
Sc 241 ricoh mp c300
LD error
LD error continues for 0.5 seconds. (After LD error is detected, a release of LD error is written to the GAVD circuit during monitoring.).
LD unit defective
Dec 03, 2013 | Ricoh Office Equipment & Supplies
Me aparece el codigo de herror sc241
Error de LD
Un error de LD continúa durante 0,5 segundos. (Después de detectarse un error de LD, se escribe una liberación de error de LD en el circuito GAVD durante la monitorización.).
• Unidad LD defectuosa
UNIDAD LD
Dos diodos láser en la unidad LD emiten 2 rayos láser de escaneo principal.
Contar con dos láseres acelera la creación de imágenes. También permite al
motor poligonal funcionar a menor velocidad, lo que reduce el ruido y prolonga la
vida del motor.
Aug 29, 2011 | Ricoh Aficio 1232C Color Copier
I have an error code that says "LD", what does
The LD stands for Long Drain and it flashes when the water level does not change after the drain pump is on. Check to see if the drain hose or drain pump is clogged or is the drain hose situated too high.
Nov 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Says LD on the panel and will not function. Cannot get any of the buttons to respond
ld is long drain error, check pump for debris. i have also had bad controller board cause this error
Oct 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washer beeps, stops, and says LD.
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error coad 322 is showing. what i do now?
ERROR 322 is Laser synchronization error
Detected LD error signal for
continuous 1.5 seconds while
polygon mirror motor was
running at constant speed.
Possible Cause • Synchronization detection mirror
defective
• LD unit defective
• FCU defective
• LD harness damaged
• THM not in place
Jan 08, 2010 | Ricoh Aficio 1013F Copier
I Kenmore Elite mod# 110.22062102
The "Ld" error means long drain. May require a new pressure switch
Aug 03, 2009 | Kenmore Washing Machines
LD error code on an old Minoltafax 1700
No, I'm afraid it's days are over.....the laser has failed.
Mar 11, 2009 | Minolta Office Equipment & Supplies
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
124 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
