Question about JVC GR-D20EK Camcorder
When a tape is loaded it is immediately ejected.
    Genius:
  • 1,812 Answers
Tape mechanism problems are quite complicated but they can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 04, 2010
Got a mitsub Hs-u430 vcr.Pluged in & immediately starts eject.Does twice then stop.Only halfway eject.Does with no tape in.Took cover off & help tape in.Push any button it does same all over.
Disc loading mechanism fault. Contact any service technician. The mechanism should be taken out from the set, for repair. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 26, 2016 | Televison & Video
Handy cam video 8 XR keeps ejecting cassette any ideas please
thats is because the servo mechanism chip do not detect the cassette,
when its in the housing could be a sensor or the cassette in switch or mechanism its self (missalignement.)
hope that will help you
regards alan.
Oct 18, 2010 | Sony Handycam CCD-TRV37 Camcorder
Tape ejects when put it in. Will not play record rewind etc. It just immediately ejects.
Check the timing of the gears. they tend to slip.
Find the loading motor. It should look like a big battery with a worm gear on the side. manually turn the gear backwards and forwards a few times. Hope this gets you watching tapes! GOOD LUCK!
Jun 17, 2010 | Sony SLV-N500 VHS VCR
When loading tape it says eject immediately
tape loader is bad. try banging the cam when tape is inside to try to realign
Jul 06, 2009 | Samsung VP-D10 Mini DV Digital Camcorder
Stuck VHS Tape/Power Issue
It sounds like the vcr is not completely loading the tape, and is overloading or getting confused. If you feel up to it, you can take the cover off the tv, find the tape loading mechanism, and 'help' the loading rollers along yourself... once the tape loads, eject it immediately, and you should be off and running again. Just be careful not to touch any electrical connections. If you're not comfortable with that, you're right, it's probably cheaper to get a newer tv - check with a local independent shop first, though, it should be a really quick fix.
Mar 14, 2009 | Samsung Televison & Video
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Sony slv 700 hf
The VCR is detecting something it doesn't like. Could be a foreign object inside, or the gearing out of time or ... Take the cover off and watch it as it loads and you'll probably figure out why.
Dec 29, 2007 | Televison & Video
The tape ejects immediately after inserting tape
your m-chassis has a problem with it and when we get these we replace the chassis and adjust them you should send to canon for repair or a qualified tech. sorry
Dec 01, 2007 | Canon ES8200V Hi-8 Analog Camcorder
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
JVC GR-D20EK Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
