Question about Singer 7436 - INGENUITY
SINGER iNGENUITY 7436 not picking up bobbin thread hitting on plastic piece
My needle hits on the plastic piece that is under the bobbin thread. The thread bunched up and then the needle started hitting. It looks like it need retiming, but I can't find out how to do that.
  • 5 more comments
  • New2sew May 11, 2008
    No we did not oil moving parts
    I have the manual and it does not have anything for this problem other than replacing the needle. I have done this and it does not fix it.
    Have done this. The bobbin is out and the black piece that holds the bobbin is also out. The needle hits the plastic piece under the bobbin holder when reverse stitching or doing regular stitch. From what I have found on this site, it needs retiming, but I can't figure out how to do that.
    I have done all of this and it still hits under the bobbin holder.
    Thanks,but this did not help resolve it either. Still not fixed.
  • Anonymous Mar 16, 2014
    how do you thread the double needle on a singer ingenuity 7436
  • Anonymous Mar 27, 2014
    cover for tension channel above the needle missing (plastic piece) ..singer #6268
    Genius:
  • 3,422 Answers
Once you have the bobbin case in with about 4 inches of thread coming off and once you have the top threaded with about 4 inches coming from the needle, take the needle thread lightly to the back and turn the balance wheel by hand towards you to pick up the bobbin thread and lay both threads to the back ready to sew.
Goodluck,
Please don't forget to rate the solution
Posted on May 11, 2008
    Genius:
  • 1,142 Answers
You need open the bobbin take it out and remove all the threads then re insert the thread in as it gets feeded this should solve the problem
  • 4 more comments
  • Maanita Chadha
    Maanita Chadha May 11, 2008
  • Maanita Chadha
    TRY THIS, THIS WILL DEFINATELY GIVE YOU SOLUTION
    http://www.singerco.com/support/faqs.htm...
  • Maanita Chadha
    This is usually caused by a problem with the bobbin case. Check the bobbin and bobbin case. Try removing and reinserting the bobbin and pull on the thread. The thread should pull easily
  • Maanita Chadha
    Try these corrections: (1) Rethread the machine; (2) Reduce the thread tension (lower number); (3) Select a larger size needle; (4) Remove and reinsert a new needle, flat side toward the back of the machine.
  • Maanita Chadha
    Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism
  • Maanita Chadha
    For online support
    The FUTURA™ support Web site URL is www.futura-support.com
    Genius:
  • 1,665 Answers
Did you oil moving parts?
How do I get my machine to start sewing and stop beeping?
try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Jun 06, 2015 | Singer 7436 - INGENUITY
Singer ingenuity 7436 manual free
Sounds like you didn't thread your Bobbin correctly
Dec 15, 2013 | Singer Sewing Machines
Upper thread keeps breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 23, 2013 | Singer 7436 - INGENUITY
The needle will not stay threaded every time i mash the peddle to start sewing, the needle comes unthreaded
Place the upper thread, along with your lower thread UNDER the presser foot....you may not be allowing enough thread off of the bobbin and roll. Pull out the thread to about 6 inches and see what happens, Happy Sewing!
Jul 23, 2011 | Singer 7436 - INGENUITY
Top thread does not engage bobbin thread
Check the needle to be sure it is not bent or mis-installed. The flat side of the needle shank faces to the back to the machine.
If this does not work, open the manual and wind and install the bobbin, then thread the machine - using the written instructions as the pictures, although helpful, can mislead.
Continue by lowering and raising the threaded needle (hold on to the end of the thread) to bring up the bobbin thread.
Pull both threads under the presser foot and to the back of the machine.
Hold onto the threads and lower the needle into the fabric and then use the power pedal to begin sewing.
If the top and bottom thread still do not form a stitch, the machine needs to go into the shop for service as the alignment needs to be adjusted.
Mar 11, 2010 | Singer 7436 - INGENUITY
Singer ingenuity 7436 needle wantpick up the bobber
a. needle in backwards
or
b. needle threaded wrong
Apr 23, 2009 | Singer 7436 - INGENUITY
Using Singer 7470 for the first time, and my bobbin thread is bunching terribly. There is a loud sound from the bobbin chamber, as if the mechanism is bouncing around??? How can I fix this bobbin issue?...
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Apr 15, 2009 | Singer 7436 - INGENUITY
Winding bobbin thread
Did you move it to the right?It has to be against the piece above the wheel.
Aug 17, 2008 | Singer 7436 - INGENUITY
Singer 7436 - INGENUITY Logo
331 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
