Question about Yamaha RX-V663 Receiver
When i put my usb it shows unknown error and it doesn't starts
  • 53 Answers
Not all usb drives will work. a simple usb pen drive will mount itself ok, but one with extra mounted drives or protection...eg Sandisk Cruzer won't as the need to 'mount' the memory area as a drive and require a more sophisticated usb interface to do this
Same thing for external usb hard drives
Posted on Sep 04, 2010
TV is not showing the USB data
maybe you did not properly select the right application in your tv... example if you play movies go to movies menu and if thats music go to music menu and also for pictures go to picture menu......or the format of you data is not supported of you TV..
Jan 12, 2014 | Computers & Internet
Default password of Samsung S3850
*#9998*289# : Change Alarm Buzzer Frequency *#9998*364# : Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*746# : SIM File Size *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*786# : Run, Last UP, Last DOWN If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0003*?# : unknown *0003*?# : unknown
*#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok *#9998*427# : Trace Watchdog *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*778# : SIM Service Table *#9998*947# : Reset On Fatal Error *#9998*872# : Diag *#9998*999# : Last/Chk *#9998*324# : Debug screens *#9998*636# : Memory status *#9998*544# : Jig detect *#9998*842# : Test ******** - Flash the screenligth during 10 seconds and vibration activated *#9998*837# : Software Version *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*9266# : Yann debug screen (=Debug Screens?)
*#9998*9999# : Software version
SP-unlock SGH-600 (and also SGH-Sgh-600 *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung SGH-600 Unlock Codes *#9999# : Show Software Version *#9125# : Activates the smiley when charging. *#0001# : Show Serial Parameters *#0837# : Show Software Version (instructions) *#06# : Show IMEI
Aug 10, 2011 | Computers & Internet
Hi, My Samsung YP-U3 has been really great up until now. But now, When I put it into my Computer (USB"s), it doesn't show up on "My Computer" (where it show's C, D, Drive etc) only...
Have you tried booting into safe mode and seeing if the problem persists? If it can be detected in safe mode, then there is a possibility your USB drivers are corrupted, and will need a re-install. To do this, remove all USB devices from ports, disable USB in your Start/Settings/Control panel/System, and reboot. Windows will then detect them at boot, and install the drivers needed to get them back up and running again.
Hope that helped.
Cheers from NZ
May 07, 2011 | Samsung YP-U3 MP3 Player
When I plug my 4gb flash it say malfunction and not recognize
have you tried putting it in a different usb port if you tried that try updating your computers usb drivers from the support site for the computer your trying to use the flash drives on
May 28, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Unknown devices
Sometimes this is because a peripheral was hooked up and then removed without finishing the install. You can usually remove the unknowns, then see if anything in your video, sound, or anything changed.
Feb 19, 2009 | Averatec 3200 Notebook
I have windows XP svpk3 OS,when i insert my 1GB moserbaer pendrive its not detected,windows showing error USB device not recognige,in divice mannager its showing UNKNOWN DEVICE whats the solution for...
Most likely the pendrive is no longer working. The simplest way to check that, is to try it in another computer and see if it's recognized. If this is the case then the USB ports on your computer are not working which I doubt.
If it is seen as unknown device that means that the electronics in the flash drive got bad and it is unrecoverable.
Jan 18, 2009 | ASUS EXTERNAL USB FLOPPY DRIVE (ASUUSBFDD)...
Unknown Device
You have install printer driver first...
Dec 05, 2008 | Computers & Internet
Uknown device Error - Canon PIXMA M180 All-In-One
just unistall the usb printing support from the device driver then you you restart then you put the printer cd in the rom and try, post your comment
May 05, 2008 | Canon MP610 Photo All-In-One Printer
Yamaha RX-V663 Receiver Logo
218 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
