Question about Philips Televison & Video
Where to find source of 3104-328-42741. - Philips Televison & Video
Hi, im strugling to answer my assignment question that says" describe the concept open software."
Is that the exact question? Or is it open source software?
Open Source Software Meaning:
In a nutshell, open source software is computer software that is distributed along with its source code - the code that is used to create the software - under a special software license. The license allows users to use, change and improve the software's source code, and to redistribute the software either before or after it has been modified. If you make any modifications to the source code, one of the conditions of open source is that you have to provide information to other developers about what has been changed, and how. The software that is created as a result of modifications to the source code may or may not be made available for free.
Aug 05, 2013 | Computers & Internet
The source selector of my onkyo A 807 runs away
HI try this video it worked for me. :)
http://www.youtube.com/watch?v=0Xfm-9jCmjE
Apr 09, 2013 | Onkyo Integra Intergrated Stereo Amplifier...
Pico 301 turn on but can not be locked on any source it just keep running the auto source finder on and on endlessly
If the set has a source button on the set itself try to defeat it (unsolder) to see if it is causing this--more common than most people think.
Dec 03, 2012 | Televison & Video
The projector finds my VGA port and projects for a second or two, and then loses it, displaying the word "lost"
First check it with new best quality VGA cable. If the problem is still there, change the source connected to VGA port (i.e. Laptop or PC). Sometimes such things occur in Auto Source. Remove Auto Source from the menu for automatic selection of source. Keep the VGA port as first source to display. You will have to check it in the menu. In spite of Auto Source you can always select your desired source with source button also. If problem is still not corrected tell us the Make & model of the projector so that it can be better diagnosed.
Aug 06, 2011 | Office Equipment & Supplies
I want to get source code for making games
Greetings..
Regarding on your concern, please visit the link below to have access and download some of the free libraries and modules including codes in creating games.
1. Free Programming Libraries and Source Code
2. Game Developer Source Code
3. Making Games in Apple
4. The C++ Source Code
5. Source Code For C++ Games
Thanks
Oct 08, 2009 | Computers & Internet
How do I get back to the right input? Model TXE2546 25" TV
To change the input source for your TV, you can use your remote to change the video source by following these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 17, 2009 | Samsung TXE2546 25" TV
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other...
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Jul 31, 2008 | Samsung Office Equipment & Supplies
Phone jack wiring
Its typical in apartments for the phones to come in through a single source and then fan out to other wire leads to the rest of the phone jacks in the place. However, I think its odd that your 'source 2' has 9 wires. I'd expect 8.
One idea is to take off a phone plate in another room and see if the wire colors on source 2 or 3 match the unknown source wires. If so, then just match the wires that connect to the same plugs in the plates.
Jan 22, 2008 | Lands Phones
Televison & Video Logo
213 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
