Question about DXG Technology Video Cameras
Took our DXG camcorder to Florida last Sept. It was working fine, up the point when we were in Florida, when it stopped working. I could turn it on, but it would shut off right away. I took the batteries out and noticed that the battery contacts looked to be corroded. I think the humidity and the salt in the air may have caused the corrosion. Should I send the camcorder in to be fixed, or is it somthing that we can do at home? Please advise. Thanks: Dave
  • 3,083 Answers
If you can clean the corrosion off down to the metal, you will be ok. Spray some electrical contact cleaner on them to flush off all the chemicals, and wipe them dry with a soft cloth. You may have to use some fine grit emery cloth to get all the corrosion and oxidation off the terminals. Then reclean them good. Corroded and oxidized battery terminals are the number one problem with digital cameras, since they use such a low voltage, and it's extremely critical to keep the contacts clean and perfectly conductive.
Cleaning the contacts should get you going again. Good luck, and thanks for using FixYa.
Posted on Sep 04, 2010
I just got my camcorder and it says I have to use windows XP etc. I have a Mac computer . What do I do now? Does that mean I can't use it?
It seems to be doomed... Maybe. Few options are out there luckily. You can design a fishbate out it, find drivers that work with WIN 7 (I couldn't), find a laptop that has the xp and the software to use your video/still files or hey, buy a "new one of these monsters for 79.99." http://reviews.cnet.com/digital-camcorders/dxg-quickshots-dxg-588v/4505-6500_7-34534364.html
Kidding and truth aside. We must consume in order to survive - thus buy some new stuff.. Cheers
Aug 17, 2013 | DXG Technology DXG QuickShots DXG-588V -...
LCD doesn't show image when I turn to take a picture in dark area. With the flash, the picture are not bright.
Even i had faced the exact problem but it was due to low battery , hope u hav checked that ... of course the pic took in dark area arent brighter than other pics ... Try hard resetting the camera by taking the batteries out for few min ...
Dec 26, 2007 | DXG Technology DXG-506V DV Digital...
I bought a used dxg 587v camcorder but did not get the cd-rom with application software. Can I down load software or do I need cd-rom and where are these items available
Here is the Manual for your DXG-587V Camcorder: DXG-587V HD User's Manual
I could only find the drivers for the DXG-589V Camcorder, and since I don't have a DXG-587V I can't test if the installation works or not, but it is worth a try. Here is your driver download: DXG-589V
Install the software after you download the driver. Plug in your Camcorder after the installation is complete. Your operating system should recognize the Camcorder and install the drivers.
If this driver doesn't work for you, you can contact DXG Customer Support to see if they can send you a Driver Disk, or a link to a working driver: http://www.dxgusa.com/online-help
Apr 14, 2011 | Video Cameras
DXG-565V Flash Media Camcorder: my DXG -565V Flash Media Camcorders sd slot wont e...
There is a spring that puts pressure on the SD card. It is most likely stuck.
You will need to fish around with a straightened paperclip, but be careful not to bend anything or the slot won't work properly any longer.
this has happened to me a few times and it's always the same fix...the spring is jammed and needs to be coerced back into place.
Hope this helps!
May 18, 2010 | DXG Technology DXG-565V Flash Media...
Snapper push lawnmower worked fine last summer thru Sept. took it out today and can't get it to crank. Any suggestions to crank lawnmower after it sit up for 6 months?
Your carburator has old fuel that has turned to "varnish" essentially. It must be removed and cleaned. Next year, run the fuel all the way out so there is none left in it to turn to varnish.
Apr 15, 2010 | Garden
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Jan 12, 2010 | DXG Technology DXG-566V Camcorder
THE PROGRAM TO EDIT THE VIDEO'S DONT WORK
if you have the proper ARC SOFT software it will work fine.
Jul 09, 2009 | DXG Technology DXG-566V Camcorder
Freezes when I try to playback video
Is your SD card formatted. I had a similar problem and then fixed it. They have pretty good phone tech support. Get the phone number from online if the above doesn't work a you can format the SD card.
Apr 21, 2009 | DXG Technology DXG-567V Flash Media...
Loading videos
DID YOU LOAD YOUR SOFTWARE?
I am having same issue . i did not load software into my computer and lost my disk . do you have a disk ? Load it
should help.
ps can you give me the disk info ..on the disk .. i need this so i to can put my stuff on my comp . thanks
Dec 09, 2008 | DXG Technology DXG DXG-301V Digital...
DXG 506V Will not turn on
I had the same problem ...I bought a new 2 GB SD card put it in the camera and it worked fine.
It may have had something to do with formatting ..I tried to format the other card wiyh my computer when the video camera would stay on.
I tried to reset the camera that didn't work either.
The new SD Card did work.
-Steve
Jun 04, 2008 | DXG Technology DXG-506V DV Digital...
Video Cameras Logo
103 people viewed this question
Top DXG Technology Video Cameras Experts
SHARCNET-USA
SHARCNET-USA
Tony Parsons
Tony Parsons
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
