Question about Universal Remote Control Televison & Video
I need the code for my mtv universal remote for a palasonic tv and the step by step instructions to install the code
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
Posted on Jun 13, 2008
  • 10 Answers
SOURCE: RCA universal remote modle #RCR311w need instructions and codes for LXI tv
RCA codes are available at http://remotefinder.rca.com/default.aspx?site=RCA
Posted on Jul 19, 2008
SOURCE: universal remote codes
I found the following web site which lists the codes for the RCA SystemLink 4 RCU400C universal remote.  It's http://www.thompsontv.com/rcarc.html.
Posted on Nov 28, 2008
http://remotefinder.rca.com/default.aspx?site=rca is the only place you have to go to. It works!
Posted on Dec 23, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
Need code for my MTV universal remote for a Toshiba DVD player
If your MTV remote control is compatible, it contains the code. Use code search to find it. If a search through all codes contained in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
Jun 17, 2017 | Toshiba Televison & Video
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    How do I program an MTV Universal remote controller to an AWA TV. I need the code for the remote controller which is a 2006 MTV Networks remote.
    Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
    http://remotesearch.blogspot.com/
    http://electro-medical.blogspot.com/
    http://electrohelponline.blogspot.com/
    Programming Notes
    • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
    • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
    This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
    Mar 13, 2016 | Universal Remote Control Televison & Video
    How do I programme my universal remote urc22b
    • If there's a book that comes with the remote follow the instructions for it. It usually tells you how to scan for the right signal. sometimes it even gives you the code for the type of tv it is.
    • If that doesn't help try checking online for the code that needs to be put in.
    • sometimes you can find step by step instructions on the website for the type of control you have.
    • If it's a tv provider remote I suggest calling your provider and they can give you step by step instructions.
    Feb 19, 2015 | Universal Televison & Video
    Misakai tv model mtv 1303 cannot find a remote for my unit that works
    buy a universal remote which has aprogramming manual. check in the manual for the relevant code of your television and follow the instructions contained in the manual. this will guide you and solve your problem.
    Sep 15, 2011 | Televison & Video
    I have MTV dvd recorder but remote not working. Need to know code to allow me to tune universal remote to allow me to use
    I have MTV DVD recorder model TS-2080 but remote not working. Need to know code to allow me to tune universal remote to allow me to use
    Jan 11, 2010 | Shenzhen Mizuda DVD-999 DVD Player
    I need the code for Sanyo tv for a 2006 mtv remote control
    Panasonic 0 0 5 1 ,0 2 5 0 ,0 0 5 5
    Please rate the help+++++Thanks for using FIXYA
    Sep 28, 2009 | Universal Remote Control 6-Device...
    Televison & Video Logo
    44 people viewed this question
    Top Universal Remote Control Televison & Video Experts
    Computer Repairing
    Computer Repairing
    Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
