Question about Kenmore 30169 Electric Single Oven
Kenmore model # 911-494-79790
It keeps showing on the oven display f4
  • 117 Answers
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Posted on May 11, 2008
  • the sensor is located inside the oven on the back at the top left side. you can access it from behind the stove
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
Oct 25, 2011 | Ovens
My oven is comimg up with the F4 fault message?
Hello Rose,
The error code F4 are code that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
The F4 error code is for sensor that has a open circuit,so instead of the 1060-1100 of a good it the display on the meter will show infinate resistiance ( the meter display will not change)
If at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
GENE
Oct 19, 2011 | Ovens
M# 911 4288816 s# OV609596Q showing a F-4 code...what does this mean?
F4 is an error code that flashes on Kenmore electric ovens when the oven's temperature sensor has shorted. You should check the wiring harness and replace the sensor if necessary.
Hope helps.
Rea
Jun 08, 2011 | Kenmore 41389 Electric Double Oven
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
The oven won't turn off and it shows a e3 f4 in the display
Hi There
I have found this for you and hope this is helpful.And let me know how it goes.
F4 Shorted oven temperature sensor Replace oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Jan 06, 2010 | Ovens
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
My kenmore oven/stove is showing F4 what is this
F4 indicates the oven temperature sensor is bad. Not knowing the exact model you have I can't give you an exact price but I've always used http://www.appliance-parts-warehouse.com/ for my parts but you're free to shop elsewhere if you plan to make the repair yourself. The part isn't very expensive and is fairly easy to install yourself.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Kenmore 30169 Electric Single Oven Logo
344 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
