Question about Dryers
I have a indesit condesor dryer model IS70CUK the water container full indicater is on even though its empty this is causing the heater not to come on and dry the washing please can you help thanks
  • kayk1 May 11, 2010
    we have done exactly what you have said and it still did not work there was alot of dust there so i cleaned it and still not working :(
I had the same problem and found the fault to be the grey box at the rear bottom on the right hand side was full of fluff blocking the flow of water i striped the side off and removed the lower filter to gain access and there's a gully that was chocked full. cleaned everything and rebuilt switched on and all was well
Posted on May 26, 2008
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
Is70cuk dryer only blowing cold air, all filters are cleaned water emptied
the one shot stat has blown on the heater. remove rear heater cover and two smaller screws holding element to the cover. you will see the two round stats. both must be replaced. part numer is 1703200, aprox £25.
Jul 06, 2011 | Indesit IS70C Electric Dryer
Indesit is70cuk the water tank is not filling. All the water is staying at the back of the machine. I have checked for blockages in the pipes and followed the instruction book.Any help please
There is also the very obvious solution that the heating element be it gas or electric is not operating correctly, check to see if one of the two breakers(for electric) or the gas burner is functioning correctly.
Jan 03, 2011 | Dryers
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Indesit Dryers
Dryer trips electricity is70cuk indesit
There is a pinched wire. need to open up the top to inspect and fix pinched wire.
Aug 01, 2009 | Dryers
Indesit condenser tumble dryer water light always on even though container empty
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Oct 06, 2008 | Dryers
Indesit condensair dryer
I have had a similar problem, my wife tried drying clothes that were too wet, causing the machine to flood. Even though she emptied the tank, the empty water light was always on!!
What I did was take the electrical plug out and tip the machine to one side, you probably will find there will be a collection of water in the base, which will leak out. Once you think you emptied it, plug it back it back in and try it.
It worked for me!
Stooooman
Aug 15, 2008 | Zanussi TC180W Electric Portable Dryer
My indesit is70c tumble dryer isnt working correctly. The light which tells you to empty the water is staying on the water draw isn't filling up with water and it does not get any heat. ( I Know I Am Blond...
problem is probably the pump that sends water up to the container. take small panel off back and pump and water container is exposed. power the pump independently and see if it works
Aug 05, 2008 | Dryers
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 | Dryers
Dryers Logo
177 people viewed this question
Top Dryers Experts
