Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
When I try to instal the Linksys E 1000 ,it says that my computer is not compatible for wireless connections ?
  • 1,472 Answers
Ycrainville
Question are you getting this message when you install the setup CD for the router. I have not see the new Linksys CD but it sounds like it may be scanning your system to see if you have a wireless card in it. If you do not then you can ignore the message.
If you do that I can help you get your computer connected after the fact. Note the only need for the CD setup is really to configure the connection between you modem and the router. All the other setting can be setup in the routers interface.
Let me know if you still have trouble getting on the internet atleast while you have the computer hard wired and we will look at your setting and connections.
After you get Internet I can help you get your wireless working. Also note when setting up a wireless router you need to do the setup while it is wires because you can change a setting that will kick you off and if you can not reconnect wirelessly you may need to reset the router and start over if you were not hard wired.
Issken
http://www.fixya.com/users/issken
Posted on Sep 04, 2010
Daisychan linksys extender 1000
I don't think it is possible.For reasons too technical for this forum, the extender does not have the ability to connect to another extender. You could try using an Access Point or router capable of working as an access point as the first extender, then using the RE 1000 to extend from that.
Mar 10, 2014 | Linksys RE 1000 Wireless-N Range Extender
My linksys e1000 router works wirelessly with all my computers except my laptop which uses windows vista SP2, my network card is atheros ar5007, and my ISP is COX. I understand that the network driver is...
Most of the times you would be right when you say its a driver issue. :)
But there are certainly few steps that you can try as in -
a) Making an other third party program manage wireless on your XP SP2 machine
b) Tweaking the wireless channels to check if there is interference(this must have minimal impact as you already state that its working with everything else).
Try downloading a third part freeware to manage your wireless connections and uninstall the arheros client.
But before doing this try with windows client as well.
What is make and manufacturer of the XPSP2 machine??
Sam
Mar 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Have 2 computer's in home, on will link t network, other will not even bring up network when attemptingto get on internet via router
Usually under these circumstances, one of your computers may not have a compatible wireless network card. An example would be if your computer has a Wireless G Network Card and your router is Wireless N, you might run into problems. You can try reinstalling the drivers for your Network Card. You can also go to the Linksys website and install the installation utility to set up the connection from scratch again.
The router itself is fine, it's the wireless card in your computer that isn't finding the router.
Jan 22, 2011 | Linksys Wireless-G WRT54G Router
Does it mean my adapter is bad if it just stays lite up green and doesn't flash to try & connect to the internet? I installed everything correctly but it still isn't working. Any ideas? I have a belkin...
The Linksys adapter should have a program you open to find and connect to your router. If not, you can use the Windows Network settings to find your router and connect. Although 54G is a slower speed, they should still connect.
Jan 28, 2018 | Linksys WRT54GX2 Wireless-G Broadband...
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
Nov 22, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Sharing internet from dlink 510g to linksys wap54g AP
yes, the manufacturer doesn't really matter as long as they are 802.11g (usually backwards compatible with a and b) so as long as the router and the adapters are installed properly NO problem
May 14, 2009 | D-Link High-Speed 802.11g Wireless PCI...
Want guests to be able to use our AT&T U-Verse broadband network.
Try checking your wireless security settings to make sure you are using the correct wireless key (password).
Apr 13, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Feb 22, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Toshiba WRC 1000 as a Wireless bridge
lets get the picture right. laptop connects to a wireless router. then u want to plug into laptop ethernet wan port of linksys ? you have to set router manual settings to gateway which is ip of toshiba... this is a fun topic. ive connected xbox360 to laptop this way.. never tried router. "fun times ahead!"
Oct 10, 2008 | Toshiba WRC 1000 Wireless...
My lap top connecting to my wireless system.
Your computer is not yet connected to the wireless network of the router. Also, make sure that your wireless computer has a wireless adapter installed on it. You may verify it on the Device Manager. If you're using a laptop with built in wireless adapter , make sure that the switch for the wireless connection is on so that it will detect the signal of the router.
Try configuring or verifying the wireless settings of the router first by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4585&p_created=1165894972&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAwNiZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aXJlbGVzcyBzZWN1cml0eQ**&p_li=&p_topview=1
After configuring or verifying the wireless settings of the router, connect your wireless computer by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_created=1160185039&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAyNSZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jb25uZWN0aW5n&p_li=&p_topview=1
If you cannot still connect wirelessly, let me know of the following:
- model number of the router
- operating system of the computer
- wireless adapter installed on the computer (built in or external)
- brand of wireless adapter installed
- wireless settings of the router (SSID, wireless security)
May 13, 2008 | Linksys Wireless-G WRT54G Router
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
43 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
