Question about Toshiba CZ36T31 36" TV
Remote does not work
Exactly same problem as other user. Tried the reset trick last fall and it worked then. However now response from remote is spasmodic. Would like to knowhow to get factory service manual so as to find out if IR is a separate board which can be replaced or if we just have to live with manual controls.
respect....
Peter
Just found this bit of info on a CZ36T31 elsewhere and am posting it in case it helps...
"...and an intermittent problem responding to the
remote. I had a service person check it out and was going to have it
repaired because it still looks and sounds very good. The part was
available at a cost of about $85-90 plus about $40 for the service.
However, the service person didn't want to come back again for
another service call because I was too far and it was not profitable
for him, so the part was never replaced.
The remote control is OK. It is the receiving module in the TV that
has a low voltage problem. If anyone is electronically handy it
probably is an easy fix to install a new module or it can be use
without the remote with the buttons on the TV."
Posted on Jan 14, 2009
Just replaced the power supply Backlight inverter to Vizio Model E470VL TV. It works fine now but I can't get the remote control or a Universal remote to work. Do I need to purchase a special remote?
If the remotes have good batteries and are both working, and the set still does not respond, you might try to reset the sets electronics. If that does not do the trick then the board responsible for responding to the remote signals generated has an issue.
Feb 23, 2017 | Vizio Televison & Video
Why wont the remote control feature work on my Panasonic TCP50UT50 Plasma, is there a feature to disable the remote, panel works well
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 21, 2015 | Panasonic Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Remote stopped working and i know there is trick to take out the batteries to reset but forgot exactly what to do
Try new batteries or a universal remote, has the remote been dropped or sat on? Some shops can fix a damaged remote, or at least check it to see if it is emmitting signal. Only programable remotes need resetting, not OEM remote.
Jun 17, 2010 | Televison & Video
Remote for playstation 3
Make sure you connect it to the PS3 via the usb cable and press the PS button in the middle. If that doesn't work there is a hidden reset button on the bottom of the controllers. Push and hold the button down for 10 seconds with an unbent paperclip or toothpick. That should do the trick.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Cannot get 27" magnavox closed caption
I called the Magnavox tech support - put the TV on channel 2,
hit the cc button repeatedly and problem solved.
thanks for contacting me.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Remote code for DAV-IS10
Hey guys I was looking around as well ...I found a universal remote that actually worked A++++ .....the name is SONY multi brand remote commander RM-V210 the trick is try under the BOSE code it worked for me picked it up at Walmart for like $12 bucks..
Dec 29, 2007 | Sony DAV-IS10 System
Problems with Wii controller
Hi try deleting controller from system. When done take batteries out for a few Min's then reinstall controller. these wii's seem to be a bit temperamental at times. See if this works.
Neil
Dec 25, 2007 | Nintendo Wii Console
Toshiba CZ36T31 36" TV Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
