Question about ASUS Eee 4G Notebook
On my ASUS eee notebook the display flipped 90 degrees. How can I get it back to normal?
  • ASUS Master
  • 32,281 Answers
To change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Posted on Sep 04, 2010
Screen is showwing everything sideways
In control panel/display somewhere in there you can flip the video horizontally and vertically maybe you have flipped it 90 degree though my computer doesn't have that option
Nov 27, 2013 | Dell Inspiron 15 (N5050)
Tip
Review Asus Eee PC 1101 HA
asus-eee-pc-1101ha.jpg The Eee PC 1101HA netbook with a 11.6-inch display. For this and its characteristics could be defined almost a notebook. Obviously, a larger than normal netbook weighs more, but the Asus Eee PC 1101HA is a netbook with mobile calling. Asus Eee PC 1101HA promises up to eleven hours of PA3420U-1BRS battery life, thanks to the Intel Atom Z520 chip.
Homes and Design
The Eee PC 1101HA has the same form "shell" 1008HA Asus Eee PC. The case is polished and its shape makes it particularly elegant netbook. We noted that despite the gloss paint handprints not remain imprinted on the case easily. This Asus Eee PC 1000H is available in white pearl, black and pink crystal.
The hinges Eee PC 1101 HA self-locking (no mechanical locking) but well hoods that limits the opening angle to a maximum of 130 degrees, this makes little netbook fittings for use legs. The screen however is quite stable.
Autonomy
Asus EeePC 1101 declares that HA is able to provide even eleven hours of VGP-BPS2C battery life. Indeed, the netbook can reach eleven hours, but with the six-cell DV1000 Battery and without Wi-Fi active since our test Eee PC 1101 HA has worked from time to time reaching autonomy of 10, 48 hours. The test was performed with a non-intensive use and without wireless enabled. With wireless enabled netbook's Inspiron XPS M1710 battery life decreases by about three hours.
Weight and Dimensions
The amp 11.6-inch display makes the netbook a bit 'pesantino (1.38 kg) obviously increases the overall dimensions: height 21.80 cm, width 28 cm, depth 19.60 cm.
Judgement
Cast a netbook for mobility, thanks to long HP dv4 Battery life, good performance that does not disdain. We can define Eee PC 1101HA netbook complete. In fact, the hardware equipment enables to easily perform common office work in comfort. With excellent value for money (currently about 360 million) this netbook is among the best in its class.
on Apr 21, 2010 | Computers & Internet
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
I accidently press something then suddenly the display panel rotated unexpectedly! Now, I don't know what to!
Hi - you probably pressed CTRL ALT Arrow Key. On Windows XP, this will rotate your display by 90 or 180 Degrees depending on which of the four arrow keys you pressed. Just try doing the same again - that should resolve it.
Sep 15, 2010 | ASUS Eee PC 900 PC Notebook
Display flipped vertical
Hi, i'm not 100% on yours, but this may well lead you in the right direction, if you right click on your desktop, a menu will pop up, select personalize, then select - display settings and do it in there.
I have nvidia control panel and i can do it in there.
There may be a short cut key, if someone else reading this might like to clarify.
Try -
ctrl - alt and arrow key to turn 90 degrees
I hope this has helped you, if you need more help please ask.
Jan 30, 2010 | Acer Aspire One PC Notebook
Screen upside down
Holding down CTRL and ALT while pressing the DOWN ARROW flips the screen upside down.
To undo it, and flip it back to normal, hold down CTRL and ALT and press the UP ARROW.
You can also try CTRL-SHIFT and then “r” … this works for some Dell configurations
This problem can also be solve in some PC using the below technique.
In Control Panel>Display>Settings tab>Advanced button, look for settings relating to display or screen position.
Newer video cards have the capability to flip the display 90 and 180 degrees for use with LCD screens that can be rotated.
If the problem still persist, Start you PC with F8 key press, select "Last known good configuration that works"
it will most probably solve the problem.
Jan 20, 2010 | ASUS Eee PC 1000H Laptop
Asus eee pc. upon startup it displays normally
ur display is not sync to the signal being rcd from the PC....visit a hardware engineer....
Dec 14, 2009 | ASUS Eee PC 1000H Laptop
ASUS ee Laptop Computer
Go into your graphics card setting and rotate the screen 90 degrees.
Jul 05, 2008 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
123 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
