Back to:
Tags:
Panasonic TH-42PX60U Television
Won't respond to volume or channel changes red... (by 7 users)
posted by srgrantham on May 11, 2008
My tv will only turn on and off, it is stuck on the same volume and aspect. remote and tv controls will not respond. red light blinks 20x's when you turn it off.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by rtr0id, posted on Oct 17, 2008
same problem here 20 blinks
Comment by dennis_walto, posted on Sep 28, 2008
Exact same problem.
Comment by rmunoz78, posted on Aug 21, 2008
Having the exact same problem, has anyone found a way to do a hard reset? I tried leaving the set unplugged overnight and it did nothing.
Comment by Guest, posted on Jul 20, 2008
We have the same issue. What did you do?
Comment by garygl, posted on Jul 06, 2008
I have the same exact problem.. Is there a reset or something I can do.. Thanks
Solution #1
posted on Oct 02, 2008
Not Rated (0)
rmunoz78
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It's definitely a firmware problem. I called Panasonic and they were very polite about the entire situation and sent me a SD card with the firmware update. If you don't have time and you're tired of listening to tv at the same volume there is a way to do a hard reset.
I figured that unplugging the unit would do this, but there is one other step that you have to do to ensure that this works.
Generally the power button on the tv is always in the "on" position, this is what allows the remote to work. In order to do a hard reset the on/off button must be in the off position. Make sure that is off, then unplug the unit, let it sit there for a minute or two and plug it back in. If the tv comes back on as soon as you plug it back into the wall/powerstrip then the button was not in the off position.
This isn't the best fix, you'll still need to get the firmware update but it will at least give you the ability to use your tv normally....well until it decides to randomly lock up on you again and you have to do this all over.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on won't respond to volume or channel changes red light blinks 20x's when turned off.:
I don't want to Accept this solution
Solution #2
posted on Oct 01, 2008
Not Rated (0)
cadink
Rating: 0%, 0 votes
called Panasonic and they said they would send me firmware 1.04 which would update my TV since it falls under the "Random lock up condition (All buttons on remote and front panel inoperative, except for Power button)" symptom which is exactly what is happening
Thank You!
Can you Help with these Flat Panel Televisions problems?
I am working on this model and the red light flashes 5...
Have white dots running horizontally across the screen....
Small red dots appear all over the screen, Most of them...
I have had my TV less than 2 years already I hate this...
Have a 20 mon. old TV just turned off by iteself while it...
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 29, 2008
I have the exact same problem. Have you found a reason ?
Loading problems.
Repair Service
Find Flat Panel TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
