Question about Whirlpool Duet GHW9150P Front Load Washer
The control panel is locked. Attempting to wash my clothes i plug in the washing machine and it says control lock and nothing else is working
  • rickeymarcus Sep 04, 2010
    if i have to pay first, how can i be sure your solution will work
  • 347 Answers
Maybe their is more to it but have you attemped to unlock the controls..on the lower right side of the control panel there is a button for the end of cycle signal (volume) if you push and hold down on this button for 3 to 4 seconde it will lock all the buttons and the unit will do nothing ,if there all ready locked push and hold this button for 3 to 4 seconds and they will unlock and unit should work as normal I hope this will help If you have a different concern after this write back and we will see what else we can do to help you out...good Luck
Posted on Sep 04, 2010
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
Light stuck on lock and wash
CHELL TRY TO DO A WASH WITH OUT CLOTHES,AND DO A SHORT PROGRAMM.
Jan 20, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Have locked the control pad accidently ad the machine won't turn on
You have not mentioned the make/model of the washer. You can remove power and when it is plugged after an hour keep the start/stop on the menu depressed.
It must clear the lock.
Nov 14, 2011 | Washing Machines
We replaced the drain pump and machine worked for a month. During the last washing the machine just stopped on spin - panel stayed on and no code has come up. The door lock switch has been replaced but...
You may have a problem in the main control. Remove power to the unit for about ten minutes and see if it resets. Otherwise you may need to call a tech.
Apr 06, 2011 | Kenmore HE2 Plus Front Load Washer
Gorenje washing machine wa 72145 washing clothes but doesnt spin keeps comimg up child lock
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | LG WM2301H Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Panel
check your owners manuel should tell you how to un lock controls wont be an obvious button as its a safety feature
Dec 31, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Control locked
Hold the "end of cycle signal" button down till its unlocked. Let me know :-)
Sep 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
