Question about Acer Aspire™ T180 PC Desktop
Acer aspire not booting up
My acer aspire t671 has suddenly stopped booting up and just shows the acer logo screen and it wont let u go into bios or anything could u please help me
  • 1 more comment
  • gothictwist Feb 04, 2009
    Same as above, cant find the reset jumper tho
  • Anonymous Mar 17, 2014
    my acer aspire 1430 power key wont turn off even after complete shutdown, with CPU still running. if left as it is on battery mode, it'll drain its battery and would flag a 'not completely shutdown' message upon re-boot.
  • Anonymous Mar 28, 2014
    no bios sequence
    Sergeant:
  • 209 Answers
Dear f1at3r1c
Righteo then, you should be starting by resetting your BIOS, and you can do this by removing the outer casing o the PC tower. Once yoiu have done this you then need to find the jumper that clears the CMOS/ BIOS. Now if you are somewhat unsure of what a jumper switch is, it just consists of a smallplatic cap which covers two metal conductive pins on the motherboard. There is usually a pin which is not covered.
Now once you have found the CMOS/ BIOS jumper setting, you will need to first remove the motherboard battery. The battery is nothing more than a glorified watch battery of the CR2032 type, and it will be silver in colour and obviously round in shape (typical cell battery).
Once you have removed the battery, you will need to then clear the CMOS/ BIOS and this is done by moving that jumper switch into the clear position. The pin that is exposed will need to be covered withthe plastic jumper, and the pin on the opposite side will need to be exposed. Leave the jumper in the clear position for about 10-20 seconds or so, and then replace it back to the original position. (doing this discharges all of the electricity in the BIOS/ CMOS chip). Once you have done this, you put the battery back in place and then start the machine, then you are good to go. Start the machine and enter the BIOS as you planned to do. You might want to consider ormatting your hard disk and re-installing windows or whatever operating system you have, and this is eeasy enough, just change the boot sequence to boot from your CD/ DVD drive first, the your hard drive second. Once its loaded up, re-enter the BIOS and reset it back to HDD first.
Now f this has not worked, then you have an oooopsie (this is my saying of oh ***T, oops, something has malfunctioned. Its more than likely to be hardware driven, so take out your hard drive first and try to boot, if it lets you bios, then you found your fault. Try this with all devices until you either find the fault, or you have narrowed this to your processor/ motherboard.
Now im sure this will solve your problem, but there is one thng you should need to know about, and it is how to identify the correct jumper. This will have either any of the following markings written on the motherboard very close to the where the jumper is. You may need glasses/ magnifyer lens in order to read the lettering, but it should say one of the following things.
CLRCMOS
CLCMOS
CLRBIOS
CMOSRST
RESET
CMOSRT
BIOSRST
CMOSCLR
CLEAR
could also be under J1, JUMPER1
Now im sure that this is the fixya for you, but if this still does not work, then please get hold of me, and i will provide you with more info.
I wish you all the best, and hope you manage to solve this issue sortly
kind regards
yours sincerely
Oz
Posted on May 11, 2008
Acer laptop display goes off after some second
Try booting into safe mode. Chances are that you have set the screen resolution and refresh rate to some value that the LCD cannot handle. That is why it works until Windows takes over. Once you are in Safe Mode you can get things under control.
Jul 20, 2014 | Acer Computers & Internet
My Acer Aspire 5732Z laptop hangs up on the Acer logo starup screen every thing stopped even cant enter the the bios hitting f2 or many other i tried
Remove ALL media, DVD, CD, USB. Unplug, remove battery, plug in, reboot. Try a system restore/recovery. At boot tap ALT+F-10 repeatedly.
Jan 25, 2013 | Acer Aspire Computers & Internet
I have an acer aspire one zg5 it boots up to the acer logo and begins to start then all of a sudden the screen goes black and a white underscore flases in the top left corner. i called acer yesterday and...
A few things to check
  • If you have any external storage (Hard drive, flash etc) plugged in, unplug and reboot. Your computer is trying to boot from these.
  • Power down the computer and unplug and remove the battery for at least 30 seconds
  • Enter BIOS (generally F9,F10,F11,F12 or del) just mash them all while the logo screen shows and check under boot devices and see if a hard drive is listed. If no then your hard drive is bad and I would send it in if under warranty
Comment back for further assistance.
Aug 20, 2011 | Acer Aspire One Netbook 8.9" Notebook
My boot priority order changed now my computer wont go to my desktop
Hi!
Sorry, I hope I was not too late. You can fix priority order issue by restoring the default value of BIOS. You can do that by doing the steps below:
1. Reboot your Acer Aspire 5315 notebook.
2. Wait about 30 seconds until you see the Acer logo on your laptop screen.
3. Press the "F2" key on the keyboard to enter the Acer Aspire 5315 laptop BIOS menu.
4. Select the BIOS option "Load Default Setting" using the arrow keys on your keyboard. Then press "Enter."
5. Press the "F10" key to save the BIOS that is reset to the factory default settings.
Hope this helps.
Apr 16, 2011 | Acer Aspire 5315 Notebook
Acer Aspire One loads to Acer page and stops loading
Here you go
http://www.youtube.com/watch?v=l6GRhsvP-og
get a flash disk and watch the video
this video explainn how to fix bios on the black screen
although yur screen shows the acer logo yu seem to be experiencing some bios trouble
So do the above
Jan 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire SA85 stays on Acer logo
Hi bob,
Usually system stops at the startup screen or the startup logo, when it finds some fault in detecting the IDE drives(ie,your harddisk or cd drive), if you dint get any get stuck in the logo, you have to see what happens at the background by clicking on f1 key or f12 or TAB or some key to show the activity rather than logo.....
After seeing the error we can conclude or decide about the problem, but when you were not able to see the screen after pressing any key as specified in your manual, Or it hangs after the LOGO screen, this must be problem with your harddrive, try changing the harddish or try connecting once again by removing it...
Enjoy Rate!
RNJ VINOD KUMAR
Jul 01, 2009 | Acer Computers & Internet
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Won't boot up
This sounds like a bios glitch. Use another computer and burn the bios to disc from Acer's support site. Run the bios flash, and then try the machine, this should clear it up.
Aug 23, 2008 | Acer Aspire 5100 Notebook
A crashed acer aspire t671-tb7z
Try pressing F12 on boot-up. I'd recommend getting another PC as I have had multiple problems with this one. Or at least make sure you back up work regularly
May 05, 2008 | Computers & Internet
BIOS setup
hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire™ T180 PC Desktop Logo
1,343 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
