Question about Maytag Washing Machines
My Maytag Front Load Washer will not spin? Any ideas on how to troubleshoot if this is a mechanical or a control problem?
  • Maytag Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 04, 2010
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Jan 06, 2015 | Maytag Washing Machines
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Front load washer walks in the spin cycle (MAH8700A*
I had this problem solved by changing this control board:
Whirlpool Part Number 34001494: CNTRL-ELEC I bought this from AMAZON for under $ 200, was able to change myself, good luck
May 26, 2014 | Maytag MAH8700A Front Load Washer
I have a Maytag Neptune front loading washer which stops at the spin cycle. I have tried turning it off and restarting from the beginning and also from the spin point. No luck. It is currently unplugged to...
try check the drain pump for any obstruction the may be stopping the flow of water or the impellar wheel itself. if there is nothing there then you may need to check the door lock mechanism or replace the main control board
Jun 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front load washer will not spin this has happened before and I called service they held down some button where the start wash etc are on on top of the washer. It washed the load but when...
Check whether water is fully drained. Since the motor worked during wash motor is not faulty.
Check relay that poers the motor during spin mode. May be micro controller fault posiible.
Mar 31, 2010 | Maytag Neptune MAH6500A Front Load Washer
The washer will not spin. A moderate thump was
resistor on control board is burnt out I think it is R14
The board on that one is located in the dryer front upper right corner you will also need io replace the wax motor in the washer door lock
Nov 04, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Water left in clothes
The shaft was designed to rotate into 2 directions: one for agitation, one for spinning. The spinning direction is controlled by a mechanism from the clutch engagement. When your plastic pulley wears out, it effects the mechanism to spin. The driving force for spinning is slipped, therefore the spin is weak As a matter of fact, the water remaining in clothes n in turn discharges to the bottom tube
Jul 02, 2009 | Maytag Washing Machines
Washer will wash but not spin
Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
407 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
