Question about Hayward H Series Pool & Spa Heater 200k Btu Propane Gas Milivolt Ignition H200p1
I have a hayward h200 pool heater. When runing it has black smoke and soot on top. Any ideas what the problem may be?
  • 990 Answers
This will one or more things (1). You will need a manometer to check the gas pressure be sure it is at 11 inches of water collom. (27 inches in 1 PSI) at the back of the gas valve. (2) make sure you have good water flow. If you have an external by-pass this should be 80-90% closed. In the water manifold you will have an internal by-pass assembly this fine tunes the water you control with the external valve. (3) make sure you don't have any derbs around the base of the heater that will block air flow. Also be sure that your heater is away from any wall or has a draft hood.
Any one or more of these things will cause sooting. When you find the culpret and fix then you will need to clean and desoot the heater. Also to avoide this in the future you should have the heater serviced every year before you put it into service.
If you do this yourself be sure to use a plastic brush and not a wire brush as any little spark with the soot can cause an explosion.
This might be one you want to get a repairman involved with and be sure he or she is a profesional.
Posted on Sep 04, 2010
Heater is smoking
when heater is cooled, remove top and clean out debris. if there is no debris, the color of smoke will indicate problem. white: condensation, rainfall etc burning off. black: burner not firing properly and sooting up. have unit serviced - clean burner assy, verify adequate gas pressure
Jun 01, 2014 | Hayward Pool & Spa
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
Hayward H250 has LO listed on the electronic panel after it had been blowing black soot out of it
check gas pressure heater overheated probably needs hi limits or fusible link plus clean heat exchange to solve
Oct 12, 2012 | Hayward H-series Electronic Gas Pool...
Why us black soot coming out hayward heater
check gas pressure if incorrect it will soot up and overheat and start to self destruct correct gas then have heater cleaned
Sep 15, 2012 | Hayward Pool & Spa
Remove high stack from Hayward H250 series pool heater
clean stack also check gas pressure sooting caused from low gas pressure plus overheating
May 25, 2012 | Hayward H250 High Wind Stack
Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Jul 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Conversion for Hayward H200 Ing Pool heater from propane to NG
I have a hayward h-2001 natural gas heater that I wish to change to propane. perhaps we can swap parts. dbkohl@prodigy.net 920-324-5652
Jun 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Black soot like smoke coming out of top of pool heater,
Your flames should be blue; orange means a poor combustion mixture. Pull the copper jets out of the manifold one at a time and inspect the inside for spider nests. They are screwed into the black tube that exits your gas valve, bends down and then along the front of the burner tubes. You will likely find most of the jets blocked. If they are not or you still have a problem after cleaning them out, you'll need a tech to measure the gas pressure in and out of the gas valve.
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 200k Btu Propane Gas Milivolt Ignition H200p1 Logo
398 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
