Question about HP Office Equipment & Supplies
Scanning feature of printer not responding - HP Office Equipment & Supplies
  • 5 more comments
  • Anonymous Jun 15, 2008
    HP Officeject 5610 printer not responding to pc.
    I've tried print test - no change
    Turn printer off - no change
  • Anonymous Jul 11, 2008
    scanner not responding
  • Sissy Anglim Jul 21, 2008
    I click scan and display reads "no scan options"
    when I press "Start Scan" display reads "no scan options"
  • Anonymous Sep 19, 2008
    i have this printer and can;t get it to scan
  • Anonymous Oct 17, 2008
    no scan option keep saying that.
  • arunquist Nov 08, 2008
    My scanner worked fine until I bought a new computer. Now the "scan" button is not lit and I cannot figure out how to get it to scan.
I figured out how to deal with the "No Scan Option" error on the HP J6480 when scanning from the panel of the printer.
The reason it did not work is because the HP Digital Image Monitor was not installed. It would not install, because I never successfully uninstalled the printer.
I followed Almost There's (HP Support Group) tips for uninstalling, namely:
1. Load the Installer CD
2. Right click CD/DVD ROM Drive (drive where you load the CD)
3. Click Explore>Open Util folder>CCC>Uninstall L1,L2 and L3. Don't uninstall L4.
4. Restart your computer then proceed reinstalling the SW.
Then I downloaded the from the HP Website the Full (not basic) software version.
I then ran it on my computer. It found the printer. Ta dah, I could scan from the printer because the HP Digital Monitor is now installed.
I do have Kaspersky Security on my computer. With firewall turned on, it still works.
I hope this helps anyone else
Posted on Jan 16, 2009
How do i scan onto my computer from my canon mp490
First install the Canon full feature software (MP Navigator EX for Windows) for your OS. If Canon doesn't have a version for your OS, you can only scan by launching software on your computer. See http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp490#DriversAndSoftware for the latest software and drivers. Make sure that the monitor feature runs at boot up (and isn't closed).
Next launch the software on your computer and use it to scan something. Under Preferences in the General tab, select the software that should acquire the scan and the folder in which you want the files stored. (In Windows, the ScanGear MP program should launch as well.) Adjust the resolution as needed. Make a note of the settings that work well for that type of scan.
Now, if you are using a USB connection to your computer, you need to set the Navigator to respond to the buttons on the all-in-one. This is under Preferences and the Scanner Button Settings tab. You need Auto > Save to PC.
If you have the all-in-one connected to your network, you must scan from the computer. (There is no way for the software to monitor button presses across the network.)
I hope this helps.
Jul 23, 2014 | Canon MP490 InkJet Printer
How can I get the software and Drivers for a Digitech XC4881 Scanner?
Try here, only thing I could find on it, if you can remember the software name it might help
Search Results for Digitech Systems Scanning Software Featured Digitech...
Seems the scanner was Discontinued by Fujitsu quite some time ago, and no longer supported for drivers.
May 22, 2014 | Office Equipment & Supplies
How can I install "scan" option in display of Canon irc3170 printer?
http://www.usa.canon.com/cpr/pdf/Brochures/copier_c3170_spec_sheet_rev.pdf
Canon Contact Us
According to the Cannon web site, the 3170 series printers do have the scan feature. I suggest you contact Cannon directly for information about the scan feature.
May 01, 2014 | Canon imageRUNNER C3170U Color Copier
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
How do i use the scan feature?
Hi Clau Martz
Read your issue. - How you can use the scan feature.
1. You can use the scan feature in this printer.
2. You can place a picture , you want to scan , facing downword on the scanning glass.
3. Close the upper cover.
4. Now open your computer and open the " Solution Center". Solution center is the software which gets installed automatically when we install the printer software.
5. Once you open the solution center, you will see the option for Scan a Document or Scan a Picture.
6. You can click on it and then it will scan that photo for you.
7. The scanned image will get stored by default in " My Documents" under the folder name " My Scans".
8. You can access your scanned image from there.
Thanks & Regards
Ashish Rohilla
Aug 09, 2010 | HP PSC 1350 All-In-One Thermal Printer
Is there an issue with the scanning feature with
this is not a wireless function sooooooooooooo in order to scan you must connect the printer and the computer with a usb cable.
Oct 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How come teh scanner isnt working for me?
Hi! I will be glad to assist you in this issue, here is the link that will help you to fix the issue,
While Scanning, the HP All-in-One or Software Does not Respond or Windows Stops Responding
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu04824&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=60630&lang=en
Computer Stops Responding When Using the Scan To Feature
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu03112&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=60630&lang=en
How to Scan in Windows XP without Using HP Software
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01843437&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=60630
Oct 11, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
SCANNER does NOT respond.
You need to have scanning software installed as well, when you press scan a program should open on your computer to accept the scans. Check in control panel then scanners and faxes and see if the scanner is there.
Jul 20, 2009 | Brother Multi-Function Center MFC-240C...
300 people viewed this question
Seeker5211
Seeker5211
