I have a carrier ac unit model#fa4bnf048 serial#0404a70001 unit in my home. The inside unit is making a loud noise what could be wrong with the unit? the unit was still cooling
    New Friend:
  • 50 Answers
Check the fan alignment and maybe there are parts vibrating or touching each other..
Posted on Sep 04, 2010
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
Carrier 2000ss will not turn on. Checked fuses and they are okay.
Inside the outside unit is a pcb with fault diagnosis lights on. It could be anything from a weak start capacitor to a compressor fault or even short of gas. See what lights are on and check the manual
Apr 21, 2012 | Carrier Heating & Cooling
Very loud clanging noises started while driving
Try to remove the belt for the ac and see if you still hear the noise, as it sounds like you may have blown the seal or bearing out of the ac compressor , not sure just a guess.
Mar 13, 2017 | 1984 Chevrolet Corvette
It is very loud inside when turned on. the noise sounds like a loud rumbleling noise.
Is this a window unit, a whole house AC, or a Split package type?
If it is a window unit remove the front cover, reach in and see if the blower fan teeters on the mother shaft. If it does the blower fan center hub has failed and the fan will need replaced. (I have changed 2 blower fans on my Carrier 19,800BTU window units that run 23 hours a day.) They just fail over time. Who knows why.
Kelly
Feb 23, 2010 | Heating & Cooling
Fan on Carrier roof top ac makes loud noise on auto or high but not on low
this one is carrier AC with bad blower motor. Hope This Helps.
Sep 29, 2009 | Heating & Cooling
There a loud noise coming from the bottom of my unit
Hi There,
Check the fan drive belt & motor. Hope this helps and thanks for using FixYa!
Mar 30, 2009 | Carrier 38CKC036 Air Conditioner
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Outside unit will not operate
Sounds like a bad fan motor. Inside fan runs, compressor runs. Outside fan. Are your contactors pulled in when thermostat set on cool? If not might be a contactor. If contactor not pulled in touch the top of it with the end of a screwdriver. If fan spins turn unit off a buy a contactor...
Tip: Always make sure power at disconnect is off
Jun 10, 2008 | Carrier 38CKC042 Air Conditioner
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
345 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
