Question about Epson Artisan 800 All-In-One InkJet Printer
Epson Artisan 800 ADF jams ever time. THere is no paper in it and I've unplugged it and restarted it multiple time. Havn't had it that long. 1 year or maybe a bit more.
    Problem Solver:
  • 5 Answers
There are two gears that are made of plastic that have hard rubber toothed sprockets pressed on them. These sprockets split and allow the drive motor to slip. Epson will only sell the motor assembly and not just the gear. I used a dot of supperglue to repair the sprockets and all works fine now.
Posted on Sep 16, 2010
  • 5 more comments
  • jrscobie Jan 06, 2011
    really, can you draw a picture of that?
    you mean the cd/dvd tray jam and then ERROR
  • chrisl4444 Jan 15, 2011
    Boy that is hard to see. little black plastic gear split in between the teeth on the motor shaft sprocket.
  • mike calabro Mar 20, 2011
    THANKS! This was a big help. On mine, it was the little black gear hub that comes off the motor spindle. It was the side that faced in toward the scanner window. I had to remove the two screws that held the motor in - and that freed it up just enough to pull it out and find the crack and drop the glue in. I did not take the motor completely out. Now, if the glue holds, I'm back in business.
  • randbd Apr 21, 2011
    Hi Riley, I hope you read this, as I have the same issue with my printer, but can you describe in more detail how you fixed your printer? I see nothing that is split or broken, and everything with regard to what you mention, i.e., the black gear hub, seems to work as it should.
  • mike calabro Apr 21, 2011
    Nothing more I can say on the description except that you need alot of light and a magnifying glass to see the crack. Mine also would "work" when not actually trying to move paper through. But when put under the stress, it would screach and not move the paper.
  • Johnny Jensen
    Johnny Jensen Aug 29, 2012
    THIS WAS THE FIX for my paper jam as well!! I want to say a huge thanks to InvisionTec for stating how to repair it.
  • Mike S Aug 22, 2013
    Thank you for the article. I just glued the black gear together and it worked. Saved me a trip in to have it serviced.
  • 3 Answers
No need to REPLACE the small motor assembly. You need to take the motor/gear assembly from the printer and inspect the inner BLACK gear on the motor drive, AND the outer BLACK gear (inspect both black gears). Both of these can crack and cause slippage on the motor axle. Here is a picture of the drive gear, that I removed the gear with slight prying pressure and added some gel superglue to it in the crack and on it's contact point to the drive axle. It's held in place, and works beautifully (I had another Artisan with the inner gear cracked, hence I knew to look at and inspect both gears);
Posted on Aug 29, 2012
  • 1 more comment
  • Larry P. Dec 14, 2012
    Johnny i just did the super glue trick on the outer gear. I did it with the motor and gear still in place. It worked, but its chattering like crazy when it runs. I guess ill have to take my time to remove motor and shaft and check both gears. Removing it is probably the way to go. The super glue i used didnt want to dry and i tried holding the 2 teeth together with apair of tweezers. There is still a small gap between the 2 teeth and i suspect its what casuign the chattering, that and maybe the inner gear is split as well. Im wondering if the replacement part is any better. I just got the exploded parts drawing from for it emailed ot me by National Parts Depot. I suspect they wouldnt know if its been changed. Theres probably a reason they used rubber, so it owuldnt strip the nylon gears.
  • Larry P. Dec 19, 2012
    Well no luck for me. I removed the motor and only the exposed gear was cracked. I pried it off the axle and glued it back together. As soon as i put it back on the axle, i split again. Maybe letting it sit for a longer period would have worked better. It still works, but is still making the same noise when the ADF runs. All other gears look fine. The replacement motor costs about $20 with shipping. May just replace it.
  • Johnny Jensen
    Johnny Jensen Dec 19, 2012
    LarryP... you have to understand, the ADF makes a lot of racket/noise even when working as-it-should. AS LONG AS it's feeding a document, it's working. Don't mind the loud clackity-clack of the drive gears and feed mechanism. Mine breaks often, and I have to repair it (with gel super glue) about every 200 pages. PITA, and I've pretty much quit using it. NOW, my scanner leaves a 1/2" dark streak down the page. I'm bummed, I really tried to like this printer (and I have two of them!)
Johnny, I can't locate the motor/gear assembly. Can you help me locate by providing a picture? All of a suddent the ADF starting jamming on me when trying to scan/copy via ADF. Your assistance is appreicated. Thanks, Jimmy
Posted on Sep 15, 2012
  • Johnny Jensen
    Maybe this picture will help?
I have the ultimate solution to this annoying problem.DONT USE THE ADF.When you close the adf lid it overrides it and diverts to the flat scanner its easier and there is no jamming.Your welcome
Posted on Jul 10, 2013
2 Suggested Answers
SOURCE: Epson Artisan 800...adf keeps saying paper jam,
ADF Motor Assembly has gears which crack. Replacement of ADF Motor Assembly normally required. Compass Micro Inc sells this part. Part #: 2132225.
Posted on Jul 30, 2011
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
The ADF jams every time on the first sheet. seems like it is just not feeding the document all the way through. what can be done?
Try opening up the LEFT side of the ADF. Takes a little finger muscle to do this. Clean the rollers with a clean cloth, and check to see that there is nothing lodged in the mechanism (staples, loose paper bits, mother-in-laws, etc). Also, there is a limit to how many sheets the ADF can take at once - I haven't maxed mine out, so I don't know how many sheets is the maximum allowed.
Hope this helps
Sep 04, 2010 | Epson Artisan 800 All-In-One InkJet...
Epson 800 adf repeatedly jams. After clearing it still jams.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 27, 2010 | Epson Artisan 800 All-In-One InkJet...
My artisan 700 keeps pilling in multiple sheets and then jams.
hi there, il be glad to assist you.
If multiple pages feed at once, remove the paper from the tray, fan the edges to separate the sheets, then reload it. if Paper Jams Inside the Artisan 700 Series: Open the scanner. Remove the paper as shown, including any torn pieces. Squeeze the hooks and remove the cover inside the Artisan 700 Series. Remove the paper as shown, including any torn pieces Reattach the cover. Close the scanner. if after doing all of these still same issue persists, if the issue persists, call epson to get a replacement printer if the product is still 1 yr. from the date of purchase, if it is more than a year, most probably, thats out of warranty,
Feb 16, 2010 | Epson Artisan 700 InkJet Printer
I have a epson artisan 800 I'm tring to fax from the automatic feeder but it keeps making a grinding sound and then it says paper jam but paper never even went through
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Jan 02, 2010 | Epson Artisan 800 All-In-One InkJet...
My Artisan 800 is having continuous paper jams, and now I think something's wrong with the nozzle or something, it seems to be having a hard time moving across and is making a crunching noise. I tried the...
please you r printer driver cd original is use. first old progreem printer driver is instol and restart pc and 10 minut wait and instoll aoriginal driver. and your printer is so the paper tray in fixed. second carteries is out of printer and so in fixed paper. and add a cartries and start printer and aply paper and aply print.
Sep 24, 2009 | Epson Artisan 800 All-In-One InkJet...
Epson Artisan 800 Scanner leaves blue/grey stripe on side.
I had this exact same issue with two Artisan 800's. I was told it was a hardware issue. Both were returned under warranty to Epson. Have since had problems with ADF and that printer was returned. Warranty has now ended. Expecting to buy a new printer shortly: they last about 4 months before having problems. It won't be an Epson even though that's all I've owned for 10 years
Sep 17, 2009 | Epson Perfection V100 Flatbed Scanner
Epson Artisan 800 All-In-One InkJet Printer Logo
5,976 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
