FixYa.com
Tags:
ECS 945G-M3  Motherboard
Ecs motherboard wiring diagram
posted by dafur on May 11, 2008
i want to connect the usb and speaker from the case
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 11, 2008
Not Rated (0)
Rubec
Rank:Wiz Wiz
Rating: 90%, 20 votes
You need to check if *********** board has the pinouts for external connctions, and if your case has the option for this. (Some do some don't) You can buy extra utility bays if your case doesn't.
Look in your manual for the MB and look for external USB and audio out connections.
If you need the manual goto: http://www.ecs.com.tw (Site is down at the mo, but try later)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Motherboards problems?
Motherboards
link is broken
hi srinubabu epox ep-4pdaei... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
ECS 945G-M3 (V3.0) Motherboard
machine got wet e machine w3619
I dried, wiped, blew,, waited,... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
