Question about Compaq Computers & Internet
My lcd screen is on pink on start up but becomes clear again after a few minutes
  • psyberslut Sep 04, 2010
    Its a laptop so only has the power cable, even when i closed the lid and reopen it again later it does the same thing
  • 10,515 Answers
If LCD screen is PINK only on START and clears later ON, this is not a good news.The backlight in a laptop is a very small fluorescent tube. When it starts to fail or the voltage is dropping it goes a pink to red color. Unfortunately, the fix would be to have the tube changed which is quiet an expensive and difficult job as it is part of the screen. If care is not taken the screen will be damaged during the changeover resulting in an expensive laptop repair. If it is caused by a reduced voltage (which is unusual) then the inverter may needs to be replaced.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 04, 2010
    President:
  • 2,185 Answers
Usually, the pink resolution of your LCD upon startup is caused by a bad connection cable. While powering it on, try twisting or tilting the cable itself as if you are looking for the right signal or connection. Please let me know how this goes.
My TCL LCD tv has colour diplay problem. While watching, after few minutes, colour will change automatically. Blue will become pink etc.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 16, 2014 | TCL L32HDM12 32 Inch LCD HDTV
Display turns dark pink for few minutes and goes
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 23, 2013 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
No screen after 5 minutes
The picture board on your monitor is bad, since it goes off after few minutes and the power led or button is on, it means the picture board of your monitor has developed fault.
I would advice you replace the picture board on the monitor, this should cost you between $65 - $85.
Take care.
Jul 06, 2010 | Soyo DYLM2286 Monitor
Sound is clear but no picture
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter for the replacement.It a long board in shape.
May 04, 2010 | Vizio L32 32 in. LCD HDTV
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
White lines and fade desktop icons on screen
The LCD screen is at fault. If your lappy is in warranty try replacing it. It would cost araound $50-$80
Thank you!
Sabharish
Jun 01, 2009 | Toshiba Satellite M30X-S181ST Laptop
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
LCD Screen going bad?
This set has had a problem with the LVDS cable from the Main PCB to the panel. The wires are delicate and the connection is not that great. Sometimes unplugging and reseating the cable does clear intermitent problems like yours up. Good Luck
Apr 22, 2007 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
