Question about Emerson LC195EMX 19 in. TV
Will not turn on - Emerson LC195EMX 19 in. TV
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
You have to ensure whether the POWER Light is ON or OFF, If off you have to check the main power regulator circuit range from AC current input. Check the Resistor , Diode, and Transistor. I am sure there are part was damaged. so you can check and replace it.
Posted on Sep 04, 2010
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Feb 11, 2017 | Buick Cars & Trucks
My rear turn signals are not working. front turn signals work rear parking lights work brake lights work
In the diagram for rear lamp, the top wires are voltage, the bottom black wire is ground. The brown wire on either side should be tail lamps, goes hot when you turn on the headlamp switch. The other top wire on either should be for turn signal. With everything turned on, is there voltage on that wire?
Because the front works and the rear don't, possible wiring circuit problem? The voltage for turn signals comes from bcm. The bcm knows when you turn on turn signal switch, either side, then the bcm sends voltage to turn signal lamp at the rear and front.
Oct 17, 2016 | 2009 Chevrolet Chevrolet HHR LS
Passenger side turn signal flashes faster but dont work even at day runing light, comes on when head lights are on, replace bulb and socket because was melted but stilldoes the same
Turn Signal Lamps
The turn signal lamps may only be activated with the ignition switch in RUN or BULB TEST position. The T/SIG fuse supplies ignition voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, the turn signal switch sends an ignition voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. When the turn signal switch receives the on-off signal it will send that signal to the following lamps on the LH or RH side:
The Rear Turn Lamp
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
Oct 11, 2015 | 2001 Pontiac Montana
Where to adjust Nissan sunny 130y carburetor idle speed n air fuel mixture
there will be screw with a spring under the head at the base of the carby
it is normally a small brass screw with a flat blade slot
turn it all the way in and then back it out around 2 turns
final tune is with the engine at operating temperature turn it in slowly until the rpms start to fall
slowly turn it back out until the rpms again start to fall
take notice of how many turns between in and out an final tune will be in 1/2 that number of turns
example
fully in then out 2 turns
turning it in and the rpms fall
turning it out and counting the number of turns gives you 1 1/2 turns till the rpms fall
turn it back in 3/4 turn
Oct 03, 2015 | Nissan Cars & Trucks
No turning signals
Turn Signal Lamps
The turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL, CORN LPS Fuse. Battery voltage is then applied through the TURN SIGNAL, CORN LPS fuse circuit to the hazard warning switch. The hazard switch supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the body control module (BCM) . The front turn lamps are grounded at G101. The rear turn lamps are grounded at G301 and G302.
Turn Signal Lamps and/or Indicators Inoperative
  1. Turn the ignition switch to the ON position.
  2. Place the turn signal switch in the LH and RH on position.
Do the turn signals operate properly?
Go to Testing for Intermittent Conditions and Poor Connections yes
Go to Step 3 no
Are all of the turn signal lamps and indicators inoperative?
Go to Step 5 yes
Go to Step 4 no
Are only the turn signal indicators inoperative?
Go to Step 16 yes
Go to Step 9 no
5
Check the TURN SIGNALS CORN LPS fuse for an open.
Is the TURN SIGNALS CORN LPS fuse open?
Go to Step 25 yes
Go to Step 6 no
6
  1. Disconnect the hazard switch.
  2. Turn the ignition to the ON position, with the engine OFF.
  3. Connect a test lamp between the ignition positive 1 voltage circuit of the hazard switch and a good ground.
Does the test lamp illuminate?
Go to Step 7 yes
Go to Step 27 no
7
Connect a test lamp between the ignition 1 positive supply voltage circuit of the hazard switch and the ground circuit of the hazard switch .
Go to Step 8 yes
Go to Step 23 no
8
  1. Install a fused jumper between the ignition 1 positive voltage circuit of the hazard switch and the turn signal flasher signal circuit of the hazard switch.
  2. Place the turn signal switch in the RH on position and the LH on position.
Do the turn signal lamps illuminate?
Go to Step 17 yes
Go to Step 15 no
9
Is a front turn signal inoperative?
Go to Step 10 yes
Go to Step 13 no
10
  2. Disconnect the inoperative front turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative front turn signal lamp and a good ground.
  4. Place the turn signal switch in the appropriate ON position.
Does the test lamp flash ON and OFF?
Go to Step 14 yes
Go to Step 11 no
11
  1. Disconnect the body control module (BCM) connector.
  2. Connect a test lamp between ground and the front turn signal switch signal circuit of the BCM.
  3. Place the turn signal switch in the appropriate ON position.
Go to Step 12
Go to Step 22
12
Test for an open or for a high resistance in the supply voltage circuit of the inoperative front turn signal lamp. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 34
Go to Step 21
13
  2. Disconnect the inoperative rear turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal lamp and a good ground.
Go to Step 14
Go to Step 28
14
Connect a test lamp between the ground circuit of the inoperative turn signal lamp and supply voltage circuit of the inoperative turn signal lamp.
Go to Step 20
Go to Step 26
15
Test for an open or high resistance in the turn signal flasher signal circuit. Refer to Circuit Testing and Wiring Repairs .
Go to Step 34
Go to Step 18
16
  1. Turn OFF the ignition.
  2. Disconnect the instrument panel cluster (IPC).
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal indicator and the instrument panel cluster (IPC) ground circuit.
Go to Step 19
Go to Step 24
17
Inspect for poor connections at the harness connector of the hazard switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 30
18
Inspect for poor connections at the turn signal switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 29
19
Inspect for poor connections at the instrument panel cluster (IPC). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 31
20
Inspect for poor connections at the inoperative turn signal lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 32
Sep 05, 2015 | 2001 Oldsmobile Intrigue
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
Oct 13, 2014 | 2013 Nissan Rogue
How to end turn
To end your turn there is an end turn in the bottom right of the screen, the turn ends when a turn timer (if enabled counts down to zero) or when all human players have pressed end turn.Turns happen one at a time except during wars (on the default settings) and the AI's turns happen simultaneously. For more info on turns look at the ingame turn settings, which explain it a bit.
Apr 12, 2014 | 2K Games Sid Meier's Civilization V for...
Turn signals wont turn off
my turn signals turn on ok but won't turn off after the turn is made, I have to manually turn them off. is this a fuse problem or could it be something else
Jan 03, 2014 | 2007 Pontiac Torrent AWD
How do you backwash your pool
if you have a sand filter or de filter turn system off then turn multiport to back wash turn back on let run until the backwash glass is clear turn off then turn to rinse turn back on for about 20 sec then turn off then turn multiport back to filter then turn back on
Oct 20, 2013 | Pentair 1.0 Hp Whisperflo Pump
Emerson LC195EMX 19 in. TV Logo
447 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
