Question about Raypak TUBE BUNDLE 263-265 VERSA - 04672F
How to fix a leaking raypak versa 265b tube bundle
  • 990 Answers
You realy can't. If it is leaking it probally has chemical damage and you may be able to fix one leak but it will leak again and soon as the walls of the pipes are worn down to the point one has broken through. So all the pipes are compromised. While your at it you may need a pilot assembly and a pressure switch and tube. Depending on damage and age of heater often it is worth thinking about a new heater.
Posted on Sep 04, 2010
I have raypak 2100 heater model pr265al-en. Its leaking water. Please help on what to look for. Mom and I live alone & last 2 times I had problems they almost scammed us.Please help,can I fix myself?
If your lucky its leaking from the drain plug or pressure switch. Take the sides off the heater. If its a simple fix you will now be able to see the leak, and should be able to make the repair yourself. if not it is undoubtedly the heat exchanger. Rheem/Raypak calls it tube bundle. I suggest a repair technician for this as there is internal parts to inspect and look for proper operation.
At least now you will have the knowledge beforehand when the technician comes and says its a 1000.00 repair its not a simple lucky fix he should have caught for a faction of the cost.
Apr 28, 2017 | Raypak Pool & Spa
Rapak above ground pool heater is leaking from the bottom
leak is prolly from pressure switch connection or heat exchanger...... if from heat exchanger buy a new heater
Aug 20, 2010 | Raypak Versa 130,000 Btu Above Ground...
Raypak versa 130 above ground natural gas heater 40 days old leaking from the bottom
bad pool chemistry heat exchange leaking replace warranty will not cover
Aug 19, 2010 | Raypak Pool & Spa
My Versa Raypak heater will not light and I am not mechanical minded enough to make repairs. Is their a Raypak authorized repair service in Lancaster, CA?
A V HAWAIIAN POOLS INC
4085 WEST AVENUE L
LANCASTER, CA 93534
(661) 943-0557
redletter-b.png 31 miles
Directions DENNIS RETTELA'S SWIMMING
11463 ORCAS AVENUE
LAKEVIEW TERRACE, CA 91342
(818) 896-4690
redletter-c.png 44 miles
Directions VALLEY HOT WATER
4212 E LOS ANGELES AVE
SIMI VALLEY, CA 93063
(805) 526-5594
Aug 04, 2010 | Raypak Versa 130,000 Btu Above Ground...
Pool heater works intermittently. have replaced thermostat kit
Depending on model you will need to ck ethier millavoltes (1/2 to 3/4 of a volt)or 24 volts. but this sounds like a pressure problem. Start by cleaning your basketsand your filter. If this dosn't help you should pull the presure switch from the manifold on the heater and see if their is any corrosen or rust on the sw or in the manifold. One of these should fix your problem. Good luck.
Nov 24, 2009 | Raypak Versa 130,000 Btu Above Ground...
I have a versa gas heater for my above ground swimming pool. This year the pilot will not light. It gets hot but will not ignite. Any ideas what could be wrong?
I have often found spiders or other **** nesting in the pilot tubes of these boilers which blocks the flow of gas. You will either need to have it professionally serviced or you can attempt to do it yourself, which I do not recommend.
Jul 11, 2009 | Raypak Versa 130,000 Btu Above Ground...
I HAVE A RAYPAK VERSA, PILOT IS ON , BURNERS DONT COME ON
check mv output of thermopile ,unless you have 350-500mv it is not enoughvoltage to power valve
Jun 07, 2009 | Raypak BURNER TRAY ASSEMBLY
Where is the pilot light on Raypak versa pool heater, i need to light it manually?
In side the front on the lower right is a long 3/8" wide tube about 5 inches long...you'll need a special lighter with an extended wick.
May 18, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak TUBE BUNDLE 263-265 VERSA - 04672F Logo
204 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
