Question about Cell Phones
When I plug in a charger the phone comes on. How do I charge the phone with the power off?
  • 1,188 Answers
After the phone has turned on when you plug it in, you can turn it off. So, plug in the charger, the phone will start charging and turn on. You can then leave the charger plugged in, but just turn the phone off and leave it charging.
Posted on Sep 04, 2010
Why does my Motorola Admiral not turn on automatically when it's plugged into a charger?
it's not to worry about your phone when your phone does not start automatic because in the only region off your better dead. you just live your phone into a charge sometimes after you can see your phone is automatic restart
May 17, 2017 | Cell Phones
Motorola A1200 cell phone battery will not charge with AC chargers
HI,
If your phone is still under warranty the best solution is to get it replaced.The problem is actually with the port of the charger.I mean the hole in which you plug in your charger isn't working properly.Where as your USB port is different and works properly so it charges the battery.So you will have to get this repaired.
Sep 18, 2008 | Motorola Mobility A1200
My phone was working last night but then i say it was low battery so i went to plug my charger in. when i plugged it in it turned off straight away and hasnt been able to turn on since. i tried plugging...
Hi, The battery cell is too weak to power up the phone.
You will have to leave the phone charging for more hours for the battery cell to come up to be able to power on the phone.
If after charging the battery for longer hours and it doesn't come up,that means the battery cell is dead and will need to be replaced with another battery.
Take care.
Jun 21, 2010 | Sony Ericsson W910i Cellular Phone
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Pantech C810/Duo Power Problem
YOU MIGHT WANT TO REPLACE THE BATTERY THE LIFE MAY BE GONE CAUSING IT TO NO LONGER CHARGE
Aug 31, 2009 | Pantech Duo Smartphone
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
May 29, 2009 | Motorola Mobility RAZR V3
Charging phone it went off wont come back on
Remove the battery and clean the contact points. Also plug in the charger and try to switch your phone on. Also notice if the normal charging logo/picture is appearing or not. If the phone does not come ON while plugged in with the charger, then its a problem of the phone. However after cleaning the battery, put it back and try to switch ON without/with the charger and let us know the results............sodeep
May 03, 2009 | LG enV VX9900 Cellular Phone
I use the phone only very occasionally. Hence very often, I let the battery die, and re-charge it when I need to use the phone. The problem is that every time after recharging it, all I can see is the...
Ok, this one is kind of odd, but through experience I know it's right. When you plug in the charger to most phones, the phone will use that power to run the phone as well as charge the battery. However, in this case, the phone does not use the power supplied by the charger except to charge the battery. So, until the battery has enough power, you cannot use it. Even though the phone is plugged into the charger, the battery is what is being used, not the power coming from the wall. I hope that was clear enough, I know it's an odd situation.
Mar 28, 2009 | Nokia 2610 Cellular Phone
Nokia N95 8gb. will not charge or power up.
That phone does charge using the USB port like other phones do. You have to use the 5v Nokia Charger that comes with the phone; it should plug-in right next to the USB port.
Mar 08, 2009 | Nokia N95 Cellular Phone
Wont charge or is locked
if you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Nov 12, 2007 | Motorola Mobility L6 Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
