Question about Toshiba Satellite Pro M15-S405 Notebook
For some reason, I can't use my touch pad. The only thing that I can do is move the cursor around on it. I have to hit enter to do everything. Did I hit a button that I don't know about. Please help me. I'm about to pull my hair out!!!
    Sergeant:
  • 281 Answers
Update your drivers
http://www.synaptics.com/support/drivers
Posted on Nov 02, 2010
Acer aspire 5735 touchpad not working properly doesn't zoom
You can try updating the software for the touch pad but the most likely problem is you have a bad touch pad. Touch pads don't necessarily go all at once. You lose some functionality. In your case, it would appear you are able to to point and move the cursor. You didn't mention, does the touchpad respond when you tap it to hit ENTER instead of hitting the ENTER key itself. This is 1 area that will commonly lose function over time as well.
Nov 10, 2011 | Acer Aspire 5735 Notebook
I cannot move the arrow
Perhaps your mouse is not plugged in to the computer. If your mouse is a usb mouse it will have an end of it that looks like this:
http://cache.gawkerassets.com/assets/images/4/2008/11/usb3.jpg
It probably isn't blue on the inside though. It's probably silver or black
If your mouse is a ps2 mouse then it will look like this:
http://www.york.ac.uk/admin/sro/Photos/PS2connection2.JPG
If the mouse is a ps2 mouse then when you plug it back in you will need to log off and then log back on to your computer for it to work. To log off you can press the windows key that looks like this:
http://daily-grind.net/wp-content/uploads/2010/08/Windows-Key-722215.jpg
and then use the tab button to navigate to the log off button and hit enter. Then hit tab until you can select yes and hit enter.
If it is a usb mouse then you can just plug it back in and it will work.
May 09, 2011 | Computers & Internet
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
As I type the cursor will jump backward whverever it wishes as follows. As I type the cursor will jump backwarderever it wishes as follows wh
This happens for 1 of 2 reasons: 1. Either your wrist hits the mouse pad and that makes the cursor move
2. If your mouse moves all the time without your control you need to have your palm rest replaced
When this works vote me a 10
Aug 22, 2010 | Dell Inspiron 1525 Notebook
When typing on hp netbook, the cursor moves around to another part of the sentence, deletes what i've typed...any thoughts on fixing this?
You need to disable the tapping while typing option in your touch pad because your thumb sometimes touches the touch pad which is causing it to move around to another part of the sentence.
Apr 15, 2010 | HP D8597A Keyboard
While I type, often the cursor moves to the poit where the mouse icon is locatde, as if the touchpad has been pressed.
yeah you have touch sensitivity set to high in the touch pad and your wrist is hitting the touch pad. go your touch pad settings in the control panel and turn it down til when your wrist brushes it, it doesn't move the mouse.
Mar 23, 2010 | Dell F3534 Touchpad
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Cursor skips lines while typing
My experience: cursor suddenly moving backward when i was typing, or moving somewhere else on the page. I would be typing and text suddenly would get highlighted. I followed someone's advice to disable the touch pad. Since I do have a mouse & key pad that was all i had to do.
HOW TO DISABLE THE TOUCHPAD FOR ACER 3680 AND OTHERS??? PRESS Fn +F7
Yep, it was that simple. At first I made sure i typed without my fingers or palms touching or near the touchpad. I noticed it seemed to stop or happen less. Soon as I disabled the touch pad all is back to normal. Yet I spent hrs trying to find out how and there were all these posts by people suggesting downloads and other more complicated things etc..
May 12, 2007 | Acer NSK8458AN Keyboard
Toshiba Satellite Pro M15-S405 Notebook Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
