Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
My fan is not blowing but it seems the compressor is running. after about 5 minutes the compressor quit running. no air coming out!
    New Friend:
  • 50 Answers
Check the rtc over load..
Posted on Sep 04, 2010
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
Aug 04, 2012 | 2010 Mercury Milan
Air Conditioner
Someone will need to find out if the compressor clutch is failing, or if it is loosing power due to a pressure switch or other problem.
A faulty relay or switch could get hot and switch off power to the compressor.
Aug 03, 2012 | 2006 Nissan Altima
Weird problem, 2005 Kia Spectra5, after air conditioning or defrost is running for about 15-20 mins, seems like the air stops blowing, even though the fan is running, turn the heat settings to fan for...
you may want to check and see if the cycling switch is defective...it engages and disengages the clutch on the compressor ..i would check and see if the clutch stops engaging when the a/c starts blowing warm
Feb 08, 2011 | Air Conditioning and Heat for Kia Spectra5
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
I own an armstrong air unit after about 30 minutes the unit seems to get hot and the fan quits the compressor is still running I changed the motor on the fan and it still does the same thing I have also...
Chech the fans rotation , the fan is suppose to blow air out the top, also if you changed the fan out ,check for the blade on right, its suppose to scoop the air from the inside and blows it out the top,, also replace the capicator...sounds to me like the motors getting too hot and tripping on internal ly high temp. Hey, slow down "Big Money"! The problem is around the fan location! Thank-you-very-much!
Aug 27, 2008 | Heating & Cooling
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
57 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
