Question about Whirlpool Duet GHW9150P Front Load Washer
The wash cycle stops before it finishes and reads either f-11 or dl. What can be done?
    President:
  • 1,932 Answers
F11 Error
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check The following things:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
F dl Error
Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check the following things
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank You
Posted on Sep 04, 2010
Washer goes through cycle, until around 11 minutes until finished it stops, and goes into dL. Will not finish load. What does this mean?
Hi.
the error F/dL means Door Lock Error
The error is prompted when the door cannot be unlocked.
Here possible causes.
Door Latch mechanism broken
Door Switch Assembly defective
Wire Harness from Central Control Unit to the Door Latch or Switch Assembly broken
Door Lock or Switch temporary failure (it can be reset disconnecting power)
You will probably need to replace the door lock assembly. Parts must be tested first.
Regards.
Ginko
Apr 28, 2011 | Kenmore HE2 Plus Front Load Washer
IT OFTEN (MORE AND MORE LATEY) WILL STOP IN THE MIDDLE OF A WASH CYCLE AND FLASH F 11 AND SOETIMES DL- I CAN'T GET IT TO START AGAIN. IT USE TO HAPPEN ONLY DURING NORMAL WASH CYCLE, BUT MORE RECENTLY, IT...
F11 indicates a problem with the Motherboard that goes into the Computer Control Unit.
Is an expensive part (£150/$200) plus labour so maybe time to just move on......
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
During every wash cycle the machine stops and the indicator light says dL we then hit pause cancel and have to start the machine on drain spin to finish the cycle
This is your door lock mechanism that is either going out ot has gone out already. How old is your washer? We are a Whirlpool factory authorized parts and service company and if you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We will get the correct part out to you asap.
We hope to be able to get you washing again soon. :<)
Nov 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
11 minutes timer flashing, machine locked
unplug washer over night. plug in try drain and spin, if it works after finish try to restart. an 11 minute stall is likely error code f / 11 or dl code starts intermittently then goes out possible ccu board under top at rear
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite will not resume cycle
need more information any error code or stopped at 11 minutes/ possible f/11, dl/f its ccu board top in back
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
F-11 code
are you using He detergant? this should help - if not it is tne main ccu not communicating w/ the washer 300 to fix
Mar 06, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
