Question about Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system
In the display window it says UPD5/5 - Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system
Is it possible to change language?
Yes, Control Panel - Regional Settings - Language.
Nov 12, 2015 | Computers & Internet
Tip
Windows Shortcut Keys
<ol> <li>Windows: Display the Start menu</li> <li>Windows + D: Minimize or restore all windows</li> <li>Windows + E: Display Windows Explorer</li> <li>Windows + F: Display Search for files</li> <li>Windows + Ctrl + F: Display Search for computer</li> <li>Windows + F1: Display Help and Support Center</li> <li>Windows + R: Display Run dialog box</li> <li>Windows + break: Display System Properties dialog box</li> <li>Windows + shift + M: Undo minimize all windows</li> <li>Windows + L: Lock the workstation</li> <li>Windows + U: Open Utility Manager</li> <li>Windows + Q: Quick switching of users (Powertoys only)</li> <li>Windows + Q: Hold Windows Key, then tap Q to scroll thru the different users on your PC</li></ol>
on Dec 27, 2010 | Computers & Internet
Tip
Here is how to connect your Windows 7 installed notebook to an external display
Most of the notebooks that were manufactured in the past two-three years come with a HDMI port along with the old VGA port to connect your computer to an external display. Connecting and activating an external display on a Windows 7 machine is pretty simple.
Here is how to connect your Windows 7 installed notebook to an external display:
1. Connect your Windows 7 laptop to the external display using VGA or HDMI cable.
2. Then, switch on your Windows 7 laptop and also the external display.
3. Once Windows 7 is up and running, type Mobility Center in Start menu search area and hit enter to open the same.
4. If you have connected your Windows 7 machine to the external display properly, you should now see Display connected text under External display section of Windows Mobility Center. To use the connected external display, click Connect Display button. You should now see your Windows 7 desktop in the external display as well.
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays
on Jun 18, 2010 | Computers & Internet
How to change language ?
You can change the display language of your Windows by following the guidelines mentioned on the links below:
For Windows 8.1
http://windows.microsoft.com/en-in/windows-8/using-multiple-languages
For Windows 7
http://windows.microsoft.com/en-in/windows7/install-or-change-a-display-language
For Windows Vista
http://windows.microsoft.com/en-in/windows-vista/change-the-display-language
GuruAid.com
Jun 06, 2015 | Computers & Internet
How do i change the screen from vertical display to horizontal
The IBM ThinkPad Z61t computer runs the Windows operating system. Normally, Windows is displayed on a monitor in a manner that makes it easy to read. If you want to change the screen display configuration (from vertical to horizontal), modify the screen display properties in Windows itself. This process causes the computer to rotate the image displayed on the screen by 90, 180 or 270 degrees, depending on the setting you choose.
1.Right-click on an empty portion of the Windows desktop on the Z61t.
2.Click "Properties."
3.Click "Display."
4.Click "Change display settings."
5.Click the "Orientation" drop-down window. Select the "Landscape" option to make the screen display items in a horizontal manner.
Sep 19, 2011 | Lenovo ThinkPad Z61t Notebook
Tip
How to connect Laptop to an External Monitor?
5. Use disconnect button in the Windows Mobility Center to disconnect the external display. When the display is connected and active, use Windows + P keys to quickly switch between these displays.
on Jun 14, 2010 | Computers & Internet
Tip
Don't Ignore the Windows Logo Key
The Windows logo key, located in the bottom row of most computer keyboards is a little-used treasure. Don't ignore it. It is the shortcut anchor for the following commands: Windows: Display the Start menu Windows + D: Minimize or restore all windows Windows + E: Display Windows Explorer Windows + F: Display Search for files Windows + Ctrl + F: Display Search for computer Windows + F1: Display Help and Support Center Windows + R: Display Run dialog box Windows + break: Display System Properties dialog box Windows + shift + M: Undo minimize all windows Windows + L: Lock the workstation Windows + U: Open Utility Manager
on Dec 15, 2009 | Computers & Internet
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
My problem is the displayed windows on my monitor/screen
Press the F8 key when windows is booting up from a power off situation, select "safe Mode" you should get a Display then,(NO Video driver(except windows generic) driver is load in safe mode). Set your display to the LOWEST resolution.. Reboot. See if you have a display with the driver set Low. If so, increase the resolution on level at a time until you encounter a problem. If you do not select Yes when windows asks if you want to keep this display setting, Windows will revert back to the last setting you selected yes for.
Apr 12, 2009 | Microsoft Windows 2000 Professional for PC
Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system Logo
2,348 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
