Question about Yamaha DVD-S1500 DVD Player
Yamaha S1800 displays "TRAY LOCKED" and the tray will not open.
SOURCE: Locked tray
Hold the open/close button on the set down until it unlocks and the tray will open in about 10secs.
Posted on Feb 04, 2007
SOURCE: no tray function
You have to press both the "on" button and the "preset" button to lock-unlock the tray
Posted on Dec 12, 2007
megatronix
  • 57 Answers
SOURCE: BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Posted on Jan 18, 2008
SOURCE: Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Posted on Feb 21, 2008
  • 150 Answers
SOURCE: dvd tray will not open
If you press the open key and it say open on the display then yu have a cut belt / blowm loading motor or power preoblem insdie the set. If it does not say open/close on the display then you could have a faultt button or processor.
Posted on May 12, 2009
How do I open my CD Tray and remove a trapped DVD? The Display shows "Locked", everytime I try to press eject button on the Receiver.
Unplug the machine. Have a look behind the tray flap. there should be a very small hole to push a paperclip or similar into to release the tray.
Mar 08, 2015 | Televison & Video
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
Locked dvd tray
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Mar 29, 2009 | Televison & Video
Locked dvd tray.
Press Setup then the numbers 2 0 0 5 then setup and it should unlock
or
Display 2 0 0 5 Display
Dec 22, 2008 | Toshiba SD-K760 DVD Player
I have a jvc th-p7 cinema system. and when i try to open the tray it say's locked. but i dont know how to take it off?????
You can lock the tray and prohibit the unwanted disc ejection.
On the center unit ONLY:
While the system is turned off
• The system turns on and "LOCKED" appears on the display
window.
• If you try to eject the disc, "LOCKED" appears to indicate that
the tray is locked.
To cancel
Carry out the same operation again.
• The system turns on and "UNLOCKED" appears on the display
window.
Nov 27, 2008 | JVC Televison & Video
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
Disc tray locked
there is a small hole outside the disk-tray. it may anywhere
put a thin needle inside that when the computer is on
warning: Be sure that you stand or touch on a wooden plank for safety
Jun 08, 2008 | Panasonic SC-HT70 System
DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Jan 18, 2008 | Sanyo DWM-390 DVD Player
Locked dvd tray.
Nov 12, 2007 | Sanyo DVD-7201 DVD Player
No tray function
Sep 26, 2007 | Yamaha DVR-S120 DVD Player
Yamaha DVD-S1500 DVD Player Logo
107 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
