Question about Whirlpool GD2SHGX Refrigerator
Whirlpool refrigerator, model G555HAXNB00 SERIAL SR2046030. Unit runs for 4 to 6hrs then the unit quite freezing and cooling. them I unplug unit for 30mins and unit start cooling and freezing. Them cooling for awhile and I have to unplug unit to get it work again, Thanks for info you can give Rodney
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 04, 2010
Westinghouse problems
From your description you have a defrost issue. I would look into why this is not defrosting in a timely manner as it is designed to. I need a model number to asset you further. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 29, 2014 | Refrigerators
Whirlpool (ER6AHKYPQoo) refrigerator temperature is hot, motor comes on and off then just stops completely. the freezer keeps cool but doesn't freeze.
the rtc contactor overload on the compressor body is not holding in anymore and is short cycling the compressor you will need to access the compressor in the rear of the unit,remove the spring clip that holds the overload rtc and run capacitor on the compressor body,then unplug this from the compressor side body and replace it,then reverse the procedure
Jan 07, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
My whirlpool gold side by side serial # slo539783 model #gd
Sound like you have a refrigerant leak I suggest to take it to a pro because you need lots of tools and knowledge to properly fix it And don?t let people tell you than is just to add refrigerant because that is a common myth or miss conception, refrigerant don?t ware out or burn out if the system need refrigerant is because there is a leak some where.
Jun 07, 2009 | Whirlpool Refrigerators
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Whirlpool Gold 25.4 cu ft side by side
After cleaning the lint you need to give the unit at least 24 hours to recuperate. If you try letting it run for 24 hours and it still doesn't work let me know if the compressor (the main motor) and the fan underneath is working and the fan in the freezer is working.
Nov 24, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator not cooling
These units suffer from freezing up the evaporator in the freezer, before loooking for a fault I would suggest turning unit off for 24hrs leaving the door open, restart and within 24hrs the unit should work ok.
Regards
Advisor
Nov 11, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GD2SHGX Refrigerator Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
