Question about Microsoft Windows XP Media Center Edition 2005 for PC
Reinstall nic1394.sys drivers
Realtek ethernet installed and dropped the 1394 connection.
How would I reinstall NIC 1394.sys drivers?
  • 2 more comments
  • Anonymous Jun 29, 2008
    Can't install NIC1394 Driver.
  • Anonymous Aug 05, 2008
    not able to access TCP/IP properties
  • Anonymous Apr 04, 2009
    same... can't find nic1394 driver
  • Anonymous Apr 10, 2009
    hf h
I can't connect my PC with my USB
Posted on Nov 24, 2008
I have a toshiba qosmio and some how the network port stopped function and I bought an external card to enable me connect to a network. It was running ok but recently, it also stopped working. The machine wouldn't recognise it. I can not connect through this port too. What could be the problem FixYa?
Posted on Jun 04, 2008
    Genius:
  • 2,785 Answers
Put in the cd containing the drivers and install it
Posted on May 13, 2008
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
No audio, no ethernet
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
May 19, 2011 | Intel 865G Motherboard
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
Apr 30, 2011 | Televison & Video
I can't find driver for onboard ethernet(RLT8168) for MSI MS-7592 Motherboard
Apr 13, 2011 | Intel Motherboard
How do i reinstall my 1394 sys driver ? not on this computor on my wife's
http://www.soft32.com/download_170557.html
here you will find a 1394 net adapter ...which is a driver for ethernet adapter (Lan) if you were talking about IEEE 1394...for fire wire ...this might be different
Sep 02, 2009 | Microsoft Windows XP Media Center Edition...
CANNOT FIND INSTALLER FOR REALTEK RTL8168C(P)8111C(P)PCI-E GIGABIT ETHERNET NIC.can u give any website 4 free download this ethernet nic
http://www.realtek.cz/realtek-driver.php?realtek=network
Select the driver you need from the list.
Jan 24, 2009 | Computers & Internet
Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Oct 30, 2008 | Gigabyte GA-M59SLI-S5 Motherboard
Corrupted network drivers
what OS are you running,
Try removing it and reinstall
if it persists then try another card
update drivers and this should fix the problem
another thing also worth thinking about....
Maybe time to consider formatting the system and reloading it again with a fresh install.
Aug 02, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Microsoft Windows XP Media Center Edition 2005 for PC Logo
11,668 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
