Question about Refrigerators
I Just installed a new dometic rm 3762 fridge in my rv. my old fridge gave out, now I have no dc power or ac power from the same connections that were working before
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
VtToolMan
  • 704 Answers
SOURCE: Just bought a tent trailer with a Dometic Fridge.
You need to make sure that you follow the manufacturer's recommendations for using the unit with each specific power source. It's important that you have the all switches in the proper position, based on what power source you're using.
Here's the manual for your model, save a copy and print it out and take some time to review the section #3 Operating Instructions on page 6.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Hope you find this helpful and will resolve your issue.
Posted on Jul 30, 2009
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Had a rain storm power went off fridge wo rks microwave works plugs I rv wrks lights in rv do not work ac does not work
sounds like one leg of the main breaker is tripped need to reset. also the a/c's in a rv require dc to operate controls. check those fuses
Sep 06, 2015 | Dometic Rooftop RV Air Conditioner
Why dometic refrig 3762 gives code E-1
faulty sensor or cable between sensor and module nott making good connection.
Jun 26, 2015 | Dometic Heating & Cooling
Hi...recently purchased a 2005 Roadtrek RV with a Dometic RM 2354 fridge in it...was getting things ready for camping and had the RV hooked up to 110 power...pushed on button for fridge and went through...
You said there was NO lights on the unit. The Dometic service manual says:
1. No operation - no panel lights: DC Volts
Fuse
Wiring
Upper Circuit Board
Lower Circuit Board
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
I would start with the DC volatage and track it back until you lose it. Most of the time it does end up being the lower circuit board though.
Aug 03, 2011 | Dometic RM2652 Refrigerator
Our dometic RM 2350caravan fridge smells like amonia when switched on to ac or dc power. It wont get cold. Help please.andrea
Hi, you have a freon leak in your system, with the caravan refrigerators they use amonia as a cooling media. You need to either have a service person the knows this system or purchase a new one. thanks.
May 18, 2011 | Dometic Refrigerators
Dometic RM 2214R
Yep, got some ideas. First off, I am not able to find information on a RM2214 fridge. Maybe the model # that you posted is incorrect? Does it say Royal, Elite or AES on the front of it?
Measure the DC connection terminal block with a volt meter. You should have at least 11 volts, but not more than 16. While you are measuring DC, change your meter over to AC volts, and measure the ripple voltage. You should not have more than half a volt AC. If so, your converter is having issues, and may have blown the control board.
Locate the control board on the back of the fridge. Unplug fridge from 120vac. Remove the plastic cover over the control board. In the top left corner of the control board, there is a 6 pin connector. Look for a loose wiring connector here. You probably will have to push it back into its socket on the circuit board.
Of course, this is assuming that you are turning the fridge on via the on/off button on the control panel...
Jul 16, 2010 | Dometic RM2852 Refrigerator
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
