Question about Evenflo Aura 3s Co Stroller
NEED A WHEEL for a straller - Evenflo Aura 3s Co Stroller
  • 439 Answers
If you call Evenflo customer service they will normally send one to you at no charge.
Posted on Sep 04, 2010
Replace front hub assembly 2002 Suzuki XL7
the front wheel bearing hub?
XL-7 (the dash matters)
my wild guess, is the questions was
what are all steps to do this job. and tools.
that?
RTM?
https://suzukipitstopplus.com/Products/10056-2002-grand-vitara-xl-7-service-manual.aspx
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
the link shows all years, and variances.
here is a photo review, that is accurate up to
1998, and beyond , if you skip the bearing service parts. as yours are INTEGRATED
and NON-serviceable.
the photo 6a and B
shows removing the hub,
so do that , buy a new hub and put it back
the same way, using the tool stated
at the stated ranges of torque
123-180 ft/lbs.
this range allows you to get the screws into the locking rings.
Dec 11, 2016 | 2002 Suzuki XL-7
How can i make wheel alignment?
need a lot more information --first need to clarify wheel alignment ,you want to do a wheel alignment ,specs on wheel alignment ,what is wheel alignment etc-------also vehicle information year make model -engine -
Sep 21, 2016 | Cars & Trucks
How to remove rear wheel
Hi, I hope I can help with this.
You should only have to remove the lug nuts and the wheel and tire will be removed. If you removed the center wheel nut then it sounds like you are trying to remove the brake rotor. To remove the wheel the 5 or 6 lug nuts need to be removed. To remove the rear spare tire there is a plastic cover to remove which then has a key hole (locks for security). You will need to unlock this as well.
Jul 28, 2016 | Cars & Trucks
I got a 1998 Nissan Pathfinder what size wheel spacers do I need to put aftermarket rims on it
1. You don't need wheel spacers for aftermarket wheels for your vehicle. Who told you did? There are a large number of wheels that will fit straight onto the vehicle and will clear the brakes no problem.
2. You will need hub centric rings with many wheels so that the wheel fits flush onto the hub mounting . The wheel dealers will provide you with the correct size hub rings when you purchase the wheels. The hub rings snap into the wheel center and are fitted to the back side of the wheel center.
What is hub centric ring
3. You need to ensure you use a wheel that is a compatible/suitable offset so that the wheel and tire will not sit too far inside the wheel well so you have sufficient inside clearance as well as sufficient clearance for the brakes. In other words suitable clearance inside and outside. If you are looking at certain wheels that will require a wheel spacer to clear your brakes you are looking at the wrong product and an unsuitable fitment for your Nissan.
Nov 03, 2015 | Nissan Cars & Trucks
Remove steering wheel on 85 dodge diplomat
Disconnect the negative battery terminal. Remove the horn pad on the steering wheel-Phillips head screws from the back side of wheel. Then loosen the nut on the steering wheel center. Mark the steering wheel to column shaft position, so the wheel goes back in exact same position on the shaft. You may need a steering wheel puller to get the wheel off the shaft, not always, but sometimes the wheel is on pretty tight. Do not hammer on the wheel to get it off, use a puller if needed. These pullers are at parts stores and not expensive.
Dec 31, 2013 | 1985 Dodge Diplomat
I ve broken 2 lugs off right rear wheel i removed tire wheel and brake cover tried to pull wheel with wheel puller it is not moving am i proceeding correctly or do i need a bigger hammer
why are you trying to pull the ( wheel ) . If you need to replace the 2 broken lugs then all you need to do id hammer them back thru the ( wheel ) and go get 2 new ones that match those broken ones and hammer them back in from the back side of the ( wheel )
Sep 14, 2011 | 1997 Oldsmobile Achieva
Rear brakes sticking
need more info---did you have brakes worked on, did it happen all of a sudden???
May 23, 2011 | 1999 GMC Sierra
A headset wire stuck (wound) in crack of steering column in 1998 Contour. How do we retrieve it? Can the wheel be dismantled?
Yes - the steering wheel can be removed, just be prepared for the wire to be smashed or mangles and unusable. Look on the back side of the steering wheel - you will see some small holes for the retaining screws for the center piece of the steering wheel. If your model has an airbag in the wheel you will need to disconnect the battery to prevent activating the airbag.Remove the panel below the steering wheel to access the harness for the airbag and unplug. Now remove those retaining screws and the center piece of the wheel. Now you will see a large nut on the center shaft of the column.Before you remove the center nut, look at how many threads are exposed above the nut before removing. Lock the steering wheel and remove that nut. Now you will need a steering wheel puller. Find the fasteners that fit your wheel and mount the puller, Turn the puller shaft 3 turns and try to remove wire - if it won't come out then you'll need to completely remove the wheel to extract the wire. Place the wheel back on the column shaft and use that center nut to re - install the steering wheel. You may need to place that nut socket over the shaft around the threaded part and tap lightly to seat the wheel far enough to use the nut to seat the wheel back down. Press steering wheel until it sits where it did in the beginning. Re - install center piece, plug in airbag and replace that lower panel. Your local auto parts store may have a steering wheel puller for rent - if not, they are not expensive to buy ( should be less than $10.00 USD).
Hope this helps!!
Dec 03, 2010 | 1998 Ford Contour
The anti-lock light came on and found out that the sensor on the right front wheel gone bad. Do i need to change all 4 sensors? How expensive is fix. need your help. Thank you.
YOU DONT HAVE TO CHANGE ALL 4 WHEEL SENSORS JUST REPLACE THE FAULTY WHEEL SENSOR.YOU NEED A HAYNES REPAIR MANUAL TO SHOW AND TELL YOU HOW TO REMOVE WHEEL SENSOR.LOCATION OF WHEEL SENSOR IN HUB BEARING ASSEMBLY ON GM CARS CHRYSLER FORD AND IMPORTS WHEEL SENSOR IS ON THE STEERING KNUCKLE
Jul 10, 2010 | 1999 Oldsmobile Alero
Need one 8" wheel
gajoey, that is in front wheel?
If it then this site can help you:
http://www.gracobaby.com/ReplacementParts/Pages/ReplacementParts.aspx
But you cant buy only one wheel for front wheel. You need to buy the whole front wheel assembly.
Hope it help your problem.
Jan 14, 2010 | Graco Quattro Tour Travel System
Evenflo Aura 3s Co Stroller Logo
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
