Canon imageRUNNER C3200 Copier Logo
Posted on Sep 04, 2010
The canon ppc( model. ir 2270) fonund the problem error code e000225-0001.i want to solution this quession.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1088
Points
Remove the front cover and take ink out from wastage unit
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Sep 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
7089
Points
37
The platen glass had been reversed when being cleaned by the technician. Make sure the platen glass has the red arrow in the rear left corner of the machine top plate.
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
1helpful
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
2helpful
E000716-0010
The error you are giving isn't a toner error. It relates to a loss of communication with the pedestal. Canon's service manual says to check the cable leading down to the pedestal. If still properly seated, replace the DC Controller Board or Pedestal Control Board.
Reference: Canon Service Manual Page 694. You may be able to locate the manual by a Google search. Search for "Canon iR4570/3570, 2870/2270 Series Service Manual"
1helpful
2870 canon copier machine showing error code E000024-0001
remove your doveloper unit and check sensor, it is luse or re fix again ,........
2helpful
2answers
Canon ir 2270 having a problem of paper jam but it doesnt show any error code can you help me solve this problem. by Fredy Gabriel
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
old marine
old marine
ZJ Limited
ZJ Limited
