Samsung WF-J1254(V/S/C/R) leaks water around the detergent door, allowing water to run down the outside of the machine, and onto the floor. This is the second machine that we have had during the last thee weeks. The first one had the same problem.
  • ColtonCat Jun 03, 2008
    I have exactly the same problem with my brand new Samsung... have no idea why it does it and there seems to be no obvious reason why?
  • yulcanada Jul 24, 2008
    My initial delivery of my Samsung WF-J1254 front-loading washer was
    replaced because the first time I used the machine it leaked all over the floor. I have had the hot water hose replaced three times. The hose seems to burst under pressure and a **** of about 1-2 inches appears on the hose. During the time I am waiting for the part to be replaced, the serviceman has advised me to use only a cold water wash cycle and the
    washer does not leak. Their technician now advises me that the housing drawer needs to be replaced. Samsung has been advised of my complaint and I continue to pay for parts and service calls.
I have finally found a reference in Samsung's own knowledgebase, online in which they indicate that this appliance was designed for European water pressure systems and that in the US and Canada, often water pressure can be much higher than in Europe (although the manual says it is good for 800kpa, which is a darn sight higher than they use in Europe, I think European domestic supply is regulated to 400kpa).
Whatever the case may be, I have noticed that my house has what appears to be rather high water pressure (subjectively of course). So, first I checked the leaking with it set to a cold only cycle, and low and behold, greatly diminished (since it was only drawing water from one line, hence a lower volume of water). Then I closed both supply taps about 2 thirds the way, and voila, problem is gone.
It makes way less noise now when filling, and I cannot really tell that the washtime has been extended excessively due to the longer fill times?
Would love some feedback if this fixes your problem?
Posted on Jun 09, 2008
I just bought it and have the identical problem!!
The water came flying out of the soap drawer and the front window and then I put it on cold and it works fine! haha
what a joke
Posted on Dec 02, 2009
SAMSUNG WF-J1254 washer very shaky when it's spinning, Help.
machine must be level there are 4 adjustable legs (1 in each corner) place a level on machine , level left to right and front to back.also check manual for initial set up there may be shipping screws that need to be removed on the back of the washer. good luck
Jun 11, 2012 | Samsung 3.7 Cu. Ft. Stackable Front-Load...
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
Bosch Axxis WFL2060 stopped working on a wash cycle. The first time I used liquid HE detergent. I am sure I put too much in and the interior foamed up, the detergent tray foamed up and came out underneath...
water in base after overfoaming has leak detection if you can tip machine back this water will run onto floor allowing unit to rest, make sure you put down some rags towel etc to trap water there will be up to a pint of water.
Jan 29, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Major leakage onto kitchen floor
If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
Regards, Biswa.
Sep 16, 2009 | Dishwashers
Suds remain after full cycle
I would personally look at a cold water supply problem, since cold water is what's used in the rinse cycle. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlets. (especially on the cold water side). Make sure they are clear of rust or debris. Check the solenoids at the inlet valve. Use a multimeter or ohmmeter to test for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. It could be a detergent or even a pump issue, but I would check the cold water supply first. Hope this helps and best wishes.
Aug 20, 2009 | Washing Machines
I set washer to be on cold/cold but it comes hot??
CHECK YOUR HOSES- SEEMS LIKE THAY ARE ON THE WRONG TAPS
Jul 06, 2009 | Washing Machines
No water is going into my bowl after I fixed mt SE problem
This is a defective inlet water valve assembly. replace it asap.
Jun 24, 2009 | Samsung WF203ANW Front Load Washer
Ma samsung wf j1254 is not stable, i leveled many times before
It could be. The front feet have to be manually adjusted but the rear feet are self leveling. If the wood is giving enough to allow the frame to touch ground then it could cause a leveling problem. The front feet are made of plastic on the newer machines if the plastic foot is stripped out, it could be allowing the machine to become un-level during operation.
Feb 22, 2009 | Washing Machines
Water leaks
I had similar issue. Fill tube running from the bottom of detergent tray to the washer drum was plugged.... (by a sock!!!). How did it get there? I'll tell you. You see the drum seal (around the inside of the door) is not a tight seal. You can actually reach up behind it from where it meets the top of the drum. Anyway in my case, a sock made it's way through that seal and outside the drum and into the drum containment vessel. So when the drum spun (to dry the clothes and empty the water) it made a terrible noise. The sock became lodged at the base of the fill tube opening and plugged it thus not allowing any water into the drum. Instead, when filling, the water just flowed out from the bottom of the detergent tray and onto the floor. I hope this helps.
Jan 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
2,256 people viewed this question
Top Washing Machines Experts
