No power up red light
Hello i have a akai 2005 model # pt5499hd it will not power up.i get 5 frashes does that mean anything .can i test anything too see
    Scholar:
  • 87 Answers
The symptom you have should be addressed by a qualified -technician. However, the most common cause is either a convergence problem or fluid leaking onto the picture tube socket or the chassis. To check for a convergence problem remove the back of the TV. Typically on Akai the convergence board may be mounted above the chassis. Look for any big aluminum heat sink with a pair of large IC`s (STK-392-040) screwed to it. Mark and unplug the power connector to the board (the red molex connector). Plug the TV in and turn on the set. If the set comes on replace the convergence IC`s and check all the 3.9 ohm (orange,white, and gold stripes) resistors on the board. To check for a fluid leak remove the lower front panel of the set and look for any moisture on or around all three picture tube sockets and the main chassis. If there is moisture, it is necessary to repair or replace the seal, wash the board or chassis and repair any damage from corrosion.
Posted on May 11, 2008
I have akai 32inch lcd tv, that will not come on... the red light stay lite. But it will not power up. Does this mean the power source is broken?
Some of the older Akai LCD TVs were known to have power supply problems. Get your model number and do a search on the internet for problems with ( your model ).
Jul 30, 2015 | Akai Televison & Video
My Akai pt5499HD has no picture to it and i just replaced the flyback transformer to see if that was the problem. any suggestions?
You need to have copy of service manual for this tv and Samsung PT5499HD service manual will work on your Akai tv as both has same circuit.
Aug 26, 2010 | Samsung HC-R4755W 47" HDTV
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Input cable piece broke off akai pt5499hd
The coaxial input can be soldered back in. You will need a new one however. Sometimes the internals in the tuner (where coaxial goes) may be damaged when coaxial connection breaks out. If that is the case a tech may charge more money. But just to replace the connection should be relatively inexpensive.
Apr 23, 2009 | Televison & Video
Digital tuner
Product Description
Akai is a company with a long history of innovation and leadership in the fields of audio and video consumer electronics. For the past decades, Akai has been a major factor in the electronics industry. From its early days of dominant marketshare in the reel-to-reel recording industry, to modern day state of the art home entertainment systems, Akai continues to be a leader in the consumer electronics industry.PRODUCT FEATURES:Console Model;Progressive Scan Converter;1080i HDTV monitor performance with add-on HDTV tuner;3D Y/C Digital Comb Filter;30-watt BBE stereo audio system;Dual HDTV component video inputs;Translucent on-screen display (OSD) system. its a add on for hdtv tuner on this model
Jan 16, 2009 | Akai PTH5498 54" Rear Projection...
AKAI PT5499HD
hello I am Jaime from Mexico, i have a 54" akai pt5492s don`t turn on, but timer on in red help me please
thanks
Sep 16, 2008 | Akai PT5492S 54" Rear Projection...
Akai pt5499hd
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
Nov 11, 2017 | Akai PTH5498 54" Rear Projection...
SCREEN FOR PT5499HD
Check this out USA AKAI CUSTOMER CARE 1-800-726-4405 Hours of operation (Eastern Time): 8:30 am ~ 9:00 pm (Monday through Friday) 9:00 am ~ 5:00 pm (Saturday) CANADA AKAI CUSTOMER CARE 1-800-293-5408 Hours of operation (Pacific Standard Time): 6:00 am ~ 6:00 pm (Monday through Friday Good Luck
Aug 15, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
