Question about Swisher 60" 13 Hp Trailmower #T1360h
Blades won't engage - Swisher 60" 13 Hp Trailmower #T1360h
  • shawb727 Sep 04, 2010
    it's a swisher 44' rough cut. when i pull the cable handle down, it doesn't engage the blades.
  • 2,382 Answers
Hi, if the Belt is Routed Properly and the Blade Brake is Working Properly, then The Spindle/Quill Assembly Shaft is Most Likely Bent also. With the Blade Brake and the Belt Off the Deck; Turn the Blade by Hand. If the Blade is Hard to Turn, then the Spindle/Quill/Mandral needs to be Replaced. Hope this Helps.
Posted on Sep 04, 2010
  • Tunde Autos
    Tunde Autos Sep 04, 2010
    Then the long spring connected to the rod inside the swisher trailmower seems to be stretched or damaged. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Furthermore there is a return spring to pull the idler pulley away from the drive belt when disengaging the blades. Check all the connections for the spring and see that the engage lever is mounted tightly. Also check the idler pulley itself.
    Pull the belt cover off on the side of the engage lever to see....
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
John Deere SST16 PTO won't engage mower blades
check for power at the clutch if no power check the safety switches and the switch itself
Apr 23, 2012 | Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
Model RZT42. When you back up the blades shut and when I go back to forward, the blades will not engage.
Some of the newer riding mowers have a safety system on them that won't let the blades work while you are backing up. If the blades are engaged and you put it in reverse they will stop. You usually have to reset the blades, turn them off then back on, when you put it back in forward.
Jul 06, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Swisher 60" 13 Hp Trailmower #T1360h Logo
381 people viewed this question
Top Swisher Garden Experts
Tim Whalen
ray gallant
john milligan
Are you a Swisher Garden Expert? Answer questions, earn points and help others
